[petsc-users] MatMatSolve in sequential call
Alexander Grayver
agrayver at gfz-potsdam.de
Mon Aug 13 10:06:20 CDT 2012
On 13.08.2012 16:54, Hong Zhang wrote:
> On Mon, Aug 13, 2012 at 8:17 AM, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
> Hello,
> Trying to call this routine on 1 proc:
> call MatMatSolve(F,B,solutions,ierr);CHKERRQ(ierr)
> I get following crash:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Null argument, when expecting valid pointer!
> [0]PETSC ERROR: Null Object: Parameter # 1!
> This indicates matrix F (factored matrix) is not provided.
> I tested petsc-3.3/src/mat/examples/tests/ex129.c with MatMatSovle():
> ./ex129 -mat_type aij -dof 2
> which works fine.
Hong,
I get matrix F as:
call PCFactorGetMatrix(pc,F,ierr);CHKERRQ(ierr)
Please note that all checks in MatMatSolve are done before this crash.
So matrix F is provided correctly and it is not zero.
The reason is that iscol and isrow == 0 here:
PetscErrorCode MatMatSolve_SeqAIJ(Mat A,Mat B,Mat X)
Mat_SeqAIJ *a = (Mat_SeqAIJ*)A->data;
IS iscol = a->col,isrow = a->row;
ierr = ISGetIndices(isrow,&rout);CHKERRQ(ierr); r = rout; <<<< crash
Again, same code runs fine when nproc > 1
> Hong
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 2, Fri Jul 13
> 15:42:00 CDT 2012
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: /app on a openmpi-i named glic1 by ag Mon Aug 13
> 15:06:36 2012
> [0]PETSC ERROR: Libraries linked from
> /home/lib/petsc-3.3-p2/openmpi-intel-complex-debug-f-ds/lib
> [0]PETSC ERROR: Configure run at Wed Jul 18 12:14:30 2012
> [0]PETSC ERROR:
> [0]PETSC ERROR: ISGetIndices() line 370 in
> /home/lib/petsc-3.3-p2/src/vec/is/interface/index.c
> [0]PETSC ERROR: MatMatSolve_SeqAIJ() line 1109 in
> /home/lib/petsc-3.3-p2/src/mat/impls/aij/seq/aijfact.c
> [0]PETSC ERROR: MatMatSolve() line 3122 in
> /home/lib/petsc-3.3-p2/src/mat/interface/matrix.c
> The same code works fine on nproc > 1.
> Any ideas?
> Regards,
> Alexander
Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120813/6443da4d/attachment.html>
