[petsc-users] SLEPc configuration error related to PETSC_ARCH
    Kyunghoon Lee
    aeronova.mailing at gmail.com
    Sun Aug 12 03:17:04 CDT 2012
Thanks for the tip; now it works fine.
K. Lee.
On Sun, Aug 12, 2012 at 2:39 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 12/08/2012, a las 06:24, Kyunghoon Lee escribió:
> > Hello all,
> > I'm having a trouble with installing SLEPc with the PETSC_ARCH variable.
>  I installed PETSc on my Linux as follows:
> > export PETSC_DIR=$PWD
> > export PETSC_ARCH=arch-linux-cxx-debug-real
> > export CXX="/usr/bin/mpicxx"
> > export CC="/usr/bin/mpicc"
> > ./configure --prefix=/home/aeronova/Development/local/lib/petsc/3.3-p2
> --download-mpich=1 --download-blacs=1 --download-metis=1
> --download-parmetis=1 --download-scalapack=1 --download-mumps=1
> --download-umfpack=1 --with-clanguage=C++
> > make PETSC_DIR=/home/aeronova/Development/local/share/petsc/3.3-p2
> PETSC_ARCH=arch-linux-cxx-debug-real all
> PETSC_ARCH=arch-linux-cxx-debug-real install
> > make PETSC_DIR=/home/aeronova/Development/local/lib/petsc/3.3-p2 test
> > Then, I tried to install SLEPc as below
> > export SLEPC_DIR=$PWD
> > export PETSC_DIR=/home/aeronova/Development/local/lib/petsc/3.3-p2
> > ./configure --prefix=/home/aeronova/Development/local/lib/slepc/3.3-p1
> > , which gives an error:
> > Checking environment...
> > ERROR: PETSc is not configured for architecture arch-linux-cxx-debug-real
> > The error is confusing since I configured/installed PETSc with
> PETSC_ARCH=arch-linux-cxx-debug-real.  I'd appreciate if someone could help
> me with this problem.
> > Regards,
> > K. Lee.
> You have to unset PETSC_ARCH. Follow the instructions in section 1.2.4 of
> SLEPc's manual.
> Jose
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120812/e6995167/attachment.html>
