[petsc-users] Configure error
Fabio fabio.pinna.2006 at gmail.com
Sat Aug 11 14:02:47 CDT 2012
I solve the configure problem, I just post what I did for future reference.
I re-installed Win SDK 7.0 and MSVC 2008 Express.
I added the variable
LIB C:\Program Files\Microsoft SDKs\Windows\v7.0\Lib;C:\Program
Files\Microsoft SDKs\Windows\v7.0\Lib\x86
to the system and user environmental variables.
I open a command prompt, I go to the directory
C:\Program Files (x86)\Microsoft Visual Studio 9.0\Common7\Tools
I run vsvars.bat.
After that I am able to compile with
cl test.cpp
the run the configure I do simply
 c:\cygwin\bin\bash.exe --login
I go to my PETSc directory and I type in
PETSC_DIR=`pwd`; export PETSC_DIR
./configure --with-cc='win32fe cl' --with-fc=0 --download-f2cblaslapack
The configure run smooth and complete its job.
Unfortunately I have a problem with make now but I'll open another thread.
Thanky you very much for your assistance
Fabio
2012/8/10 Satish Balay <balay at mcs.anl.gov>:
> On Fri, 10 Aug 2012, Fabio wrote:
>> A simple test.cpp complains about kernel32.lib. My bad, I didn't mean
>> to waste your time.
>> Can I add all the linker option in  --with-cc='win32fe cl
>> all-options-VC-need' or I should do it some other way?
> Perhaps you need to reinstall your compiler.
> Satish
