[petsc-users] Segmentation Violation
Matthew Knepley
knepley at gmail.com
Fri Aug 10 20:46:23 CDT 2012
On Fri, Aug 10, 2012 at 8:22 PM, Peter Zhoujie Lu <lzj at umich.edu> wrote:
> Dear all,
> I have some issue with my code using petsc. The exact same code runs fine
> on a linux box with ifort. Is that still be a possible memory corruption? I
> have some issue with getting valgrind working on 10.7. Is there any better
> way to debug this? Thanks. Here is the error message I got for OSX 10.7
> with gcc.
This is almost certainly you passing in an invalid pointer for the Vec you
are creating. Why not just use gdb? Also,
everyone here has valgrind running on OSX.
Matt
> Peter
> 0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: --------------------- Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [0]PETSC ERROR: INSTEAD the line number of the start of the function
> [0]PETSC ERROR: is given.
> [0]PETSC ERROR: [0] VecCreateMPIWithArray line 312
> /Users/lvzhoujie/Work/petsc-3.3-p2/src/vec/vec/impls/mpi/pbvec.c
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 59.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> p.s. I also found /src/ksp/pc/examples/test/ex7.c not working on my
> computer. Here is the error message:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Object is in wrong state!
> [0]PETSC ERROR: Must call MatXXXSetPreallocation() or MatSetUp() on
> argument 1 "mat" before MatSetValues()!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 2, Fri Jul 13 15:42:00
> CDT 2012
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./ex7 on a linux-ifo named peter-lu by plu Fri Aug 10
> 21:06:23 2012
> [0]PETSC ERROR: Libraries linked from
> /Users/lvzhoujie/Work/petsc-3.3-p2/linux-ifort-opt/lib
> [0]PETSC ERROR: Configure run at Fri Aug 10 10:44:21 2012
> [0]PETSC ERROR: Configure options --with-pic --download-openmpi=1
> --with-fortran=1 --with-debugging=1 --with-shared-libraries=1
> --download-superlu_dist=yes --with-fortran-interfaces=1
> --with-scalar-type=real --download-f-blas-lapack --with-cc=gcc
> --with-fc=gfortran --with-cxx=c++ --with-petsc-arch=linux-ifort-opt
> --download-parmetis=yes --download-metis
> [0]PETSC ERROR:
> [0]PETSC ERROR: MatSetValues() line 993 in
> /Users/lvzhoujie/Work/petsc-3.3-p2/src/mat/interface/matrix.c
> [0]PETSC ERROR: main() line 25 in src/ksp/pc/examples/tests/ex7.c
> with errorcode 73.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120810/fd4f4c5f/attachment.html>
