[petsc-users] Configure error
Fabio fabio.pinna.2006 at gmail.com
Fri Aug 10 07:24:34 CDT 2012
I updated to the last version of Petsc then I used again
PETSC_DIR=`pwd`; export PETSC_DIR
then in the petsc directory
./configure --with-cc='win32fe cl' --with-fc=0
--download-f2cblas-lapack --with-mpi-dir=/cygdrive/c/Program\ Files\
\(x86\)/MPICH2
Now I have an error,
"Nonexistent directory /cygdrive/c/Program\ Files\ \(x86\)/MPICH2"
The directory anyway is there and cygwin could easily access it
Also trying with mpi-include/lib gives the same error.
What can I do?
Fabio
2012/8/10 Satish Balay <balay at mcs.anl.gov>:
> Why use this very old version petsc-2.3.3?
> If this old version is really needed - you might want to copy over
> bin/win32fe/* files over from the latest version.
>> --with-mpi-dir=/cygdrive/c/Program\ Files\ \(x86\)/MPICH2
> I don't remember if it will handle current mpi - so might want to use
> --with-mpi-include/--with-mpi-lib options. Also the braces in the PATH
> can potentially cause problem.
> Satish
> On Fri, 10 Aug 2012, Fabio wrote:
>> I forgot to say that I start cygwin from the MSVC 2008 Expresse prompt
>> and that running cl does produce some output (basically prviding an
>> help for the cl function)
>> 2012/8/10 Fabio <fabio.pinna.2006 at gmail.com>:
>> > I followed your advice and I installed the binary version of MPICH for
>> > win 32 bit.
>> > Than I prepared the envirnmental variable with
>> > ./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe f90'
>> > --download-f-blas-lapack --with-mpi-dir=/cygdrive/c/Program\ Files\
>> > \(x86\)/MPICH2
>> > and I got the error
>> > "C compiler you provided -with-cc win32fe cl does not work"
>> > Part of the log look like this
>> > sh: /cygdrive/d/Workspace/PETSc/petsc-2.3.3-p13/bin/win32fe/win32fe cl
>> > -c -o conftest.o   conftest.c
>> > Executing: /cygdrive/d/Workspace/PETSc/petsc-2.3.3-p13/bin/win32fe/win32fe
>> > cl -c -o conftest.o   conftest.c
>> > sh: Warning: win32fe: Path Not Found: C:\PROGRA~2\MICROS~1.0\SharedIDE\BIN
>> > conftest.c
>> > conftest.c
>> >                                           Pushing language C
>> >                                           Popping language C
>> >                                           Pushing language Cxx
>> >                                           Popping language Cxx
>> >                                           Pushing language FC
>> >                                           Popping language FC
>> >                   Pushing language C
>> >                   Popping language C
>> >  -o conftest.exe     conftest.o
>> > cl  -o conftest.exe     conftest.o
>> > LINK : fatal error LNK1104: cannot open file 'kernel32.lib'
>> > Possible ERROR while running linker:  output: Warning: win32fe: Path
>> > ret = 512
>> > so it look like a directory problem, but the installation is standard,
>> > maybe I cannot use it with MS Visual C++ 2008 Express?
>> > Thank you for your time.
>> > Fabio
>> > 2012/8/6 Barry Smith <bsmith at mcs.anl.gov>:
>> >> On Aug 5, 2012, at 5:19 PM, Fabio <fabio.pinna.2006 at gmail.com> wrote:
>> >>> Thank you for your quick reply,I will try with a reboot.
>> >>> Regarding the compiler my idea was to use MSVC express 2008. I thought
>> >>> it was possible to compile both library with gcc under cygwin.
>> >>> From your reply I guess this is not the case.
>> >>> Does this mean I should compile Petsc with MSVC express as well, isn't it?
>> >>    Yes, you need to compile PETSc with the compiler you would like to use and make sure to use the MPICH binary install  since that works with the Microsoft compilers.
>> >>    Barry
>> >>> Fabio.
>> >>> 2012/8/5 Satish Balay <balay at mcs.anl.gov>:
>> >>>> On Sun, 5 Aug 2012, Fabio wrote:
>> >>>>> Dear all,
>> >>>>> I am new to petsc, and I've been struggling with it for the last days.
>> >>>>> I want to install it on Windows 7, and first  I tried to install the
>> >>>>> Microsoft MPI and then compiling the MPICH. They both seems ok but I
>> >>>>> am not able to compile Petsc with any of them.
>> >>>>> I am mostly interested to MPICH (for portability).
>> >>>>> I used this script to configure
>> >>>>> ./config/configure.py PETSC_ARCH=win32-gnu  --with-fc=0
>> >>>>> --download-f2cblaslapack=1
>> >>>>> –with-mpi-dir=/cygdrive/d/Workspace/MPICH/mpich2-1.4.1p1
>> >>>> What compilers do you plan to use? MS C/C++ or cygwin gcc/g++?
>> >>>> [MS MPI is for use with MS compiler only. MPICH binary install is for
>> >>>> MS compilers, and MPICH source install is for cygwin gcc/g++]
>> >>>>> and I've got this error,
>> >>>>>                    UNABLE to EXECUTE BINARIES for config/configure.py
>> >>>>> [Errno 16] Device or resource busy: 'conftest.exe'
>> >>>>> This error seems to happen pretty randomly at differente places in the script.
>> >>>>> Any idea to solve this problem?
>> >>>> Its bad file locks on windows. The only suggestion we have is reboot.
>> >>>> For some cygwin issues - you need to run 'rebaseall' but this doesn;t apper to be
>> >>>> that issue.
>> >>>> If you still have issues - send the complete log [and logfile] to petsc-maint.
>> >>>> Satish
>> >>>>> Thank you all
>> >>>>> Fabio
