[petsc-users] create a sparse symmetric matrix
Thu Aug 9 22:20:40 CDT 2012
On Thu, Aug 9, 2012 at 10:09 PM, Yifei Li <yifli82 at gmail.com> wrote:
> On Thu, Aug 9, 2012 at 10:59 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Thu, Aug 9, 2012 at 9:53 PM, Yifei Li <yifli82 at gmail.com> wrote:
>>> Matt,
>>> Thanks.  I have another two related questions:
>>> 1) So just because I did not get the correct value doesn't mean the
>>> symmetric matrix is not setup correctly?
>> Right.
>>> 2) Which function should I use to retrieve the value then? I can't get
>>> the correct value even though I disabled MPI when  building PETSC?
>> Since it would require communication, there is no easy way to do this.
>> Why would you need this?
> I just want to make sure the lower triangular part gets the same values as
> the upper triangular part.
That is what View() is for.
   Matt
>>    Matt
>>> Yifei
>>> On Thu, Aug 9, 2012 at 8:45 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Thu, Aug 9, 2012 at 5:20 PM, Yifei Li <yifli82 at gmail.com> wrote:
>>>>> Hi all,
>>>>> I only filled the entries in the upper triangular part of the matrix,
>>>>> however, I got  0 when I tried to get the value of some entry in the lower
>>>>> triangular part.
>>>>> Here's how I do it:
>>>>> MatCreate(PETSC_COMM_WORLD, &A);
>>>>> MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE, n, n);
>>>>> MatSetType(A, MATSEQSBAIJ);
>>>>> MatSetUp(A);
>>>>> // I set the value for the entry at (0, 2)
>>>>> int i = 2, j = 0;
>>>>> MatGetValues(A,1,&i,1,&j,values);
>>>> MatGetValues() is not synchronous, so it would not be able to
>>>> communicate to the
>>>> correct process to retrieve the values. Thus, you cannot retrieve the
>>>> lower triangle.
>>>> This is analogous to only having access to local values with
>>>> VecGetArray().
>>>>    Matt
>>>>>  Any help is highly appreicated.
>>>>> Yifei
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120809/16edf9f8/attachment.html>
