[petsc-users] create a sparse symmetric matrix
Yifei Li
yifli82 at gmail.com
Thu Aug 9 21:53:17 CDT 2012
Matt,
Thanks. I have another two related questions:
1) So just because I did not get the correct value doesn't mean the
symmetric matrix is not setup correctly?
2) Which function should I use to retrieve the value then? I can't get the
correct value even though I disabled MPI when building PETSC?
Yifei
On Thu, Aug 9, 2012 at 8:45 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Aug 9, 2012 at 5:20 PM, Yifei Li <yifli82 at gmail.com> wrote:
>> Hi all,
>> I only filled the entries in the upper triangular part of the matrix,
>> however, I got 0 when I tried to get the value of some entry in the lower
>> triangular part.
>> Here's how I do it:
>> MatCreate(PETSC_COMM_WORLD, &A);
>> MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE, n, n);
>> MatSetType(A, MATSEQSBAIJ);
>> MatSetUp(A);
>> // I set the value for the entry at (0, 2)
>> int i = 2, j = 0;
>> MatGetValues(A,1,&i,1,&j,values);
> MatGetValues() is not synchronous, so it would not be able to communicate
> to the
> correct process to retrieve the values. Thus, you cannot retrieve the
> lower triangle.
> This is analogous to only having access to local values with VecGetArray().
> Matt
>> Any help is highly appreicated.
>> Yifei
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120809/ae3c131a/attachment.html>
