[petsc-users] Field split questions
Matthew Knepley
knepley at gmail.com
Wed Aug 8 22:52:03 CDT 2012
On Wed, Aug 8, 2012 at 10:51 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Aug 8, 2012 at 10:23 PM, Colin McAuliffe <cjm2176 at columbia.edu>wrote:
>> Thanks all, regarding use of DM in 3.3, is the procedure now to create
>> the fields with PCFieldSplitSetIS and then use DMCreateFieldDecompositionDM
>> to create a new DM based from the new fields and the DM for the original
>> problem?
> 1) Use petsc-dev
> 2) PCFieldSplitSetIS() is independent. This allows you to define splits
> however you want, but then recursive gets harder
> 3) In 3.3., it uses DMCreateFieldDecompositionDM() to split all fields
> apart at once
> 4) In petsc-dev, it uses DMCreateSubDM() which can split off any
> combination of fields, which from the command line is something like
> -pc_fieldsplit_0_fields 2,0 -pc_fieldsplit_1_fields 1,3
I should have shown recursive:
-fieldsplit_0_pc_type fieldsplit
will split 2,0 into two blocks.
Matt
> Matt
>> Colin
>> Colin McAuliffe
>> PhD Candidate
>> Columbia University
>> Department of Civil Engineering and Engineering Mechanics
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120808/be36695d/attachment.html>
