[petsc-users] Field split questions
Colin McAuliffe
cjm2176 at columbia.edu
Wed Aug 8 22:23:50 CDT 2012
Thanks all, regarding use of DM in 3.3, is the procedure now to create
the fields with PCFieldSplitSetIS and then use
DMCreateFieldDecompositionDM to create a new DM based from the new
fields and the DM for the original problem?
Colin
Quoting Matthew Knepley <knepley at gmail.com>:
> On Wed, Aug 8, 2012 at 9:12 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Aug 8, 2012, at 9:08 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> > Barry - you forgot to commit/push the interface files in
>> > src/ksp/pc/impls/fieldsplit/ftn-custom.
>> Thanks. I forgot to hg add the new files :-(
>> > http://petsc.cs.iit.edu/petsc/petsc-dev/rev/40f9515d8b01
>> > Perhaps this interface addition can go into petsc-3.3?
>> No
>> > That patch [with a minor fix] can be easily applied to petsc-3.1 to
>> > get the link working. [old iffy functionality is a different matter :)]
>> Users are free to shot themselves in the foot if they want to so Colin
>> certainly could back-port this but I recommend upgrading.
> Colin, I also recommend upgrading since with the new stuff, you should be
> able to do everything you want
> to do from the command line without messing around pulling out KSP objects.
> Matt
>> Barry
>> > Satish
>> > On Wed, 8 Aug 2012, Barry Smith wrote:
>> >> Well the field split stuff in 3.1 is rather iffy anyways. You really
>> need to take the couple hours and do the upgrade before trying to add new
>> features to the fortran code you are using. The time to upgrade will be
>> much less than time spent in work arounds.
>> >> Barry
>> >> On Aug 8, 2012, at 8:52 PM, Colin McAuliffe <cjm2176 at columbia.edu>
>> wrote:
>> >>> Is there an alternative to this routine that will allow me to define
>> hierarchical field splits in 3.1p8? It will be a fairly significant
>> undertaking to upgrade the fortran code I am using to be compatible with
>> newer versions of petsc.
>> >>> Colin
>> >>> Quoting Barry Smith <bsmith at mcs.anl.gov>:
>> >>>> Colin,
>> >>>> I'm sorry we never had a FORTRAN interface for this routine.
>> You'll need to switch to petsc-dev
>> http://www.mcs.anl.gov/petsc/developers/index.html to use that function.
>> >>>> Barry
>> >>>> On Aug 8, 2012, at 7:54 PM, Colin McAuliffe <cjm2176 at columbia.edu>
>> wrote:
>> >>>>> Thanks I will look into DM. Is PCFieldSplitGetSubKSP in petsc
>> version 3.1p8 callable from fortran? I am getting the following error
>> when I compile the fortran code, and I cant figure out if this is an error
>> in my code or what.
>> >>>>> Undefined symbols for architecture x86_64:
>> >>>>> "_pcfieldsplitgetsubksp_", referenced from:
>> >>>>> _umacr6_ in umacr6.o
>> >>>>> ld: symbol(s) not found for architecture x86_64
>> >>>>> thanks
>> >>>>> Colin
>> >>>>>> On Wed, Aug 8, 2012 at 8:48 AM, Colin McAuliffe <
>> cjm2176 at columbia.edu>wrote:
>> >>>>>>> Hello all,
>> >>>>>>> When using PCFieldSplitSetIS to define splits within splits,
>> should the IS
>> >>>>>>> contain indices in the original matrix or in the next highest
>> split level?
>> >>>>>> The next highest split level. You might consider using a DM if you
>> have
>> >>>>>> some structure (like discretization on a mesh).
>> >>>>>> This should handle all the index-wrangling for you. It is new, but
>> intended
>> >>>>>> for just this kind of thing.
>> >>>>>> Also, my matrix is in aij format but one of the sub fields has a
>> block
>> >>>>>>> diagonal structure. Is it still possible use block jacobi on this
>> field?
>> >>>>>> Yes.
>> >>>>>> Matt
>> >>>>>>> Thanks and all the best
>> >>>>>>> Colin
>> >>>>>>> Colin McAuliffe
>> >>>>>>> PhD Candidate
>> >>>>>>> Columbia University
>> >>>>>>> Department of Civil Engineering and Engineering Mechanics
>> >>>>>> What most experimenters take for granted before they begin their
>> >>>>>> experiments is infinitely more interesting than any results to
>> which their
>> >>>>>> experiments lead.
>> >>>>>> -- Norbert Wiener
>> >>>>> Colin McAuliffe
>> >>>>> PhD Candidate
>> >>>>> Columbia University
>> >>> Colin McAuliffe
>> >>> PhD Candidate
>> >>> Columbia University
> experiments lead.
> -- Norbert Wiener
Colin McAuliffe
PhD Candidate
Columbia University
