[petsc-users] Customizeing MatSetValuesBlocked(...)
Jinquan Zhong
jzhong at scsolutions.com
Wed Aug 8 16:45:54 CDT 2012
It is a 1D matrix in PETSc. I just passed it as a 2D matrix in ScaLAPACK. It is still a 1D matrix when get back into PETSc.
Jinquan
From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Jed Brown
Sent: Wednesday, August 08, 2012 2:27 PM
To: PETSc users list
Subject: Re: [petsc-users] Customizeing MatSetValuesBlocked(...)
PETSc does NOT use a 2D partition. You need to get that concept out of your head.
On Wed, Aug 8, 2012 at 3:09 PM, Jinquan Zhong <jzhong at scsolutions.com<mailto:jzhong at scsolutions.com>> wrote:
Satish,
I looked at
http://www.mcs.anl.gov/petsc/petsc-current/src/snes/examples/tutorials/ex5s.c.html
where
MatCreateAIJ(PETSC_COMM_WORLD,rend-rstart,rend-rstart,N,N,5,0,0,0,&J);
was used to create J (N,N) with local J dimensioned as (rend-rstart,rend-rstart).
For my application, I have LDA=LDB=3 and N=9 in the following
ierr = MatCreateAIJ(PETSC_COMM_WORLD,LDA,LDB,N,N,LDA,0,0,0,&A); CHKERRQ(ierr);
I got the following error message:
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Nonconforming object sizes!
[0]PETSC ERROR: Sum of local lengths 27 does not equal global length 9, my local length 3
likely a call to VecSetSizes() or MatSetSizes() is wrong.
It does NOT appear PETSc had the 9x9 matrix. It tried to build 27*27 since I am using 9 procs. Is there a way to resolve this local size and global size issue?
Jinquan
-----Original Message-----
From: petsc-users-bounces at mcs.anl.gov<mailto:petsc-users-bounces at mcs.anl.gov> [mailto:petsc-users-bounces at mcs.anl.gov<mailto:petsc-users-bounces at mcs.anl.gov>] On Behalf Of Satish Balay
Sent: Wednesday, August 08, 2012 1:45 PM
On Wed, 8 Aug 2012, Jed Brown wrote:
> On Wed, Aug 8, 2012 at 2:25 PM, Jinquan Zhong <jzhong at scsolutions.com<mailto:jzhong at scsolutions.com>>wrote:
> > If I understand you correctly, ScaLAPACK blocks don't have anything
> > to do with the sparse matrix structure.****
> > You are correct. What I meant was how to define the diagonal and
> > off-diagonal parts of each submatrix matrix A (LDA, LDB). For
> > example, in the following matrix,****
> > *Proc0* *Proc1* *Proc2*****
> > 1 2 0 | 0 3 0 | 0 4****
> > *Proc0* 0 5 6 | 7 0 0 | 8 0****
> > 9 0 10 | 11 0 0 | 12 0****
> > 13 0 14 | 15 16 17 | 0 0****
> > *Proc3* 0 18 0 | 19 20 21 | 0 0 <=== owned by Proc 5****
> > 0 0 0 | 22 23 0 | 24 0****
> > *Proc6* 25 26 27 | 0 0 28 | 29 0****
> > 30 0 0 | 31 32 33 | 0 34****
> > I am not sure how to fill out the values for d_nz, d_nnz,o_nz, o_nnz
> > peoperly for the subblock (0 0 ;0 0; 24 0) owned by Proc 5 since it
> > was based on diagonal and off-diagonal parts.
> Throw your 2D block cyclic nonsense out the window. These are sparse
> matrices and that layout would be terrible. Logically permute your
> matrices all you want, then define a global ordering and chunk it into
> contiguous blocks of rows (no partition of columns). Work this out
> with a pencil and paper. You should have a function that translates
> row/column pairs from your ordering to our ordering. Now compute the
> sparsity pattern in the new ordering. (Usually you can figure this out
> on paper as well.) Then preallocate and call MatSetValues() with the new (row,column) locations.
also check the 'example usage' at:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateAIJ.html
Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120808/99388acf/attachment-0001.html>
