[petsc-users] Customizeing MatSetValuesBlocked(...)
Jinquan Zhong
jzhong at scsolutions.com
Wed Aug 8 13:37:33 CDT 2012
Dear PETSc folks,
I have an emerging need to resolve the performance issue in building sparse matrix in PETSc.
I am are currently having some performance issues in building the sparse matrix in PETSc. I am trying to input the inverted matrix from ScaLAPACK into PETSc. This matrix is partitioned into series of submatrices with indices identified as block-cyclically distributed pattern.
Here are the options I have tested in PETSc to build them into PETSc and their limitations:
1. MatSetValue(s)(...) is very easy to use. However, the assembling process is extremely slow and expensive;
2. MatSetValuesBlocked(..) can speed up the assembly. However, it is not well-fit for block-cyclically distributed matrices; and
3. MatCreateMPIAIJwithArrays(...) seems to be promising. However, it is not straightforward to use for block-cyclically distributed matrices.
4. Customizeing MatSetValuesBlocked(...) such that we can specify the indices for (*mat->ops->setvaluesblocked)(...). However, I have trouble to locate proper line for
mat->ops->setvaluesblocked=&unknownFunctionName
The question is what other options you have to resolve this performance issue? From your experience, do you guys have a worked example to build PETSc sparse matrix from block-cyclically distributed matrices obtained from ScaLAPACK with good performance?
I appreciate your inputs on this issue.
Jinquan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120808/cb995c79/attachment.html>
