[petsc-users] petscvec.mod version problem
Tue Aug 7 16:30:42 CDT 2012
There is a version of the module compiled using an older compiler version.
It could come from here or from system paths. You have to track down the
stray module file and delete it (or at least get it out of a path searched
by the compiler).
On Tue, Aug 7, 2012 at 3:28 PM, Peter Zhoujie Lu <lzj at umich.edu> wrote:
> Hi All,
> I am trying to compile my code that uses petscvec, I got an error about
> version of petscmod.mod. I tried to search online, but couldn't find the
> answer. I was wondering if anyone can help. I am using gfortran, openmpi on
> OSX 10.7. The petsc version is 3.3-p2. Thanks.
> Peter
> openmpif90 -I../../mod -I../../externals/SU_MPI/mod
> -I../../externals/ADT/mod -I../../src/python/fortran/aeroElastic
> -I../../src/inputParam -I../../src/turbulence  -I/opt/local/include
> -DHAS_ISNAN  -fpic -r8 -O2 -g
>  -I/Users/lvzhoujie/Work/petsc-3.3-p2/include
> -I/Users/lvzhoujie/Work/petsc-3.3-p2/linux-ifort-opt/include
> -I/Users/lvzhoujie/Work/petsc-3.3-p2  -c getADjoint.F90 -o
> ../../obj/getADjoint.o
> getADjoint.F90:18.14:
>   use petscvec
>               1
> Fatal Error: Wrong module version '9' (expected '4') for file
> 'petscvec.mod' opened at (1)
> make[4]: *** [getADjoint.o] Error 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120807/ce90de8a/attachment.html>
