[petsc-users] direct solver question
Tue Aug 7 13:59:25 CDT 2012
On Tue, Aug 7, 2012 at 1:53 PM, Tabrez Ali <stali at geology.wisc.edu> wrote:
>  Matt
> So if I want to use a direct solver I should really use (2) instead of (3).
To guarantee robustness, yes.
   Matt
> Tabrez
> On 08/07/2012 01:05 PM, Matthew Knepley wrote:
> On Tue, Aug 7, 2012 at 12:48 PM, Tabrez Ali <stali at geology.wisc.edu>wrote:
>> Barry
>> So which one of the two gives the correct solution? And yes the condition
>> number is high.
>> Actually I am trying to solve a trivial quasi-static problem with the
>> following flags
>> (1) -ksp_type gmres -pc_type asm
>> (2) -ksp_type gmres -pc_type lu -pc_factor_shift_type nonzero
>> (3) -ksp_type preonly -pc_type lu -pc_factor_shift_type nonzero
>  This does no iterative refinement, so you are stuck with the initial
> accuracy of the LU
> factorization, which can be bad for an ill-conditioned matrix.
>     Matt
>> The results at t=0 for all three cases are equivalent.
>> For the time dependent part (linear system is solved again), results from
>> (1) and (2) are the same. But (3) gives a very different answer.
>> I also solve the same quasi-static problem using a different code (does
>> not use PETSc) and the results obtained are similar to (1) and (2).
>> So basically I am trying to understand why '-ksp_type preonly' gives me a
>> (potentially) wrong solution.
>> Thanks
>> Tabrez
>> On 08/07/2012 12:01 PM, Barry Smith wrote:
>>> On Aug 7, 2012, at 12:06 PM, Tabrez Ali<stali at geology.wisc.edu>  wrote:
>>>  Hello list
>>>> By any chance is using
>>>> similar to
>>>> -ksp_type preonly -pc_type lu?
>>>> Should the results be equivalent?
>>>> T
>>>     The should be similar but will not be identical necessarily, in
>>> particular when the matrix is ill conditioned they can be very different
>>> and in fact GMRES may iterate a few times.
>>>     Barry
>> No one trusts a model except the one who wrote it; Everyone trusts an
>> observation except the one who made it- Harlow Shapley
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120807/5acb04b7/attachment.html>
