[petsc-users] direct solver question
Tabrez Ali
stali at geology.wisc.edu
Tue Aug 7 12:48:18 CDT 2012
Barry
So which one of the two gives the correct solution? And yes the
condition number is high.
Actually I am trying to solve a trivial quasi-static problem with the
following flags
(1) -ksp_type gmres -pc_type asm
(2) -ksp_type gmres -pc_type lu -pc_factor_shift_type nonzero
(3) -ksp_type preonly -pc_type lu -pc_factor_shift_type nonzero
The results at t=0 for all three cases are equivalent.
For the time dependent part (linear system is solved again), results
from (1) and (2) are the same. But (3) gives a very different answer.
I also solve the same quasi-static problem using a different code (does
not use PETSc) and the results obtained are similar to (1) and (2).
So basically I am trying to understand why '-ksp_type preonly' gives me
a (potentially) wrong solution.
Thanks
Tabrez
On 08/07/2012 12:01 PM, Barry Smith wrote:
> On Aug 7, 2012, at 12:06 PM, Tabrez Ali<stali at geology.wisc.edu> wrote:
>> Hello list
>> By any chance is using
>> similar to
>> -ksp_type preonly -pc_type lu?
>> Should the results be equivalent?
>> T
> The should be similar but will not be identical necessarily, in particular when the matrix is ill conditioned they can be very different and in fact GMRES may iterate a few times.
> Barry
No one trusts a model except the one who wrote it; Everyone trusts an observation except the one who made it- Harlow Shapley
