[petsc-users] with hypre
Barry Smith
bsmith at mcs.anl.gov
Fri Aug 3 14:36:10 CDT 2012
On Aug 3, 2012, at 2:31 PM, Amneet Bhalla <mail2amneet at gmail.com> wrote:
> I see... Do I need to have some external package for gamg? I am getting this error
> Unable to find requested PC type gamg!
> Also its not listed in -pc_type options when I do -help
You should be using PTESc 3.3 or petsc-dev
Barry
> On Fri, Aug 3, 2012 at 2:21 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Aug 3, 2012, at 1:34 PM, Amneet Bhalla <mail2amneet at gmail.com> wrote:
> > Thanks Matt for pointing to Makefile manual. I just included these lines
> > include $(PETSC_DIR)/conf/variables
> > LIBS = $(PETSC_LIB)
> > in the hypre's makefile and it is now working. This issue is resolved. I will try to write preconditioner using hypre's multigrid solvers.
> > Example files which you pointed for AMG and ML are for non-linear solvers and distributed arrays. The
> > equation I am solving is linear for which I have a sparse matrix MPIAIJ. Is it possible to use multigrid solvers
> > in PETSc without going through the process of again creating new arrays/matrices?
> Yup, that is exactly what the hyper BoomerAMG, Trilinos ML and PETSc gang solvers are for.
> Barry
> Amneet
