[petsc-users] with hypre
Matthew Knepley
knepley at gmail.com
Fri Aug 3 14:03:21 CDT 2012
On Fri, Aug 3, 2012 at 1:34 PM, Amneet Bhalla <mail2amneet at gmail.com> wrote:
> Thanks Matt for pointing to Makefile manual. I just included these lines
> include $(PETSC_DIR)/conf/variables
> LIBS = $(PETSC_LIB)
> in the hypre's makefile and it is now working. This issue is resolved. I
> will try to write preconditioner using hypre's multigrid solvers.
> Example files which you pointed for AMG and ML are for non-linear solvers
> and distributed arrays. The
> equation I am solving is linear for which I have a sparse matrix MPIAIJ.
> Is it possible to use multigrid solvers
> in PETSc without going through the process of again creating new
> arrays/matrices?
The point is that if you just use -pc_type gamg from the command line it is
no different for these examples. They
also build sparse matrices underneath.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120803/e58c0621/attachment.html>
