[petsc-users] PCFIELDSPLIT and RHS
tribur burckhardt at itis.ethz.ch
Thu Aug 2 06:58:07 CDT 2012
Dear PETsc team,
We are confrontated with the problem of a complex-valued equation
system M * z = (A + i*B) * (x + i*y) = b + i*c which shows slow
convergence using GMRES and, e.g., Block Jacobi or SOR as
preconditioner.
To be able to use algebraic multigrid preconditioning, we are trying to
solve the equivalent real-valued system (A -B; B A) * (x; y) = (b; c)
using PCFIELDSPLIT and, e.g.,
-ksp_type fgmres -pc_type fieldsplit -pc_fieldsplit_type schur
-pc_fieldsplit_schur_fact_type full -fieldsplit_real_ksp_type gmres
-fieldsplit_real_ksp_max_it 10 -fieldsplit_real_pc_type bjacobi
-fieldsplit_real_sub_pc_type lu -fieldsplit_imag_ksp_type fgmres
-fieldsplit_imag_ksp_max_it 10 -fieldsplit_imag_pc_type none
However, PCFIELDSPLIT does'nt work due to the lacking convergence of
ksp(A) with the right hand side bTmp given by the current FGMRES
iteration (outer loop). kspSolve(kspA, b, x) converges acceptably fast
using, e.g., GMRES and Block Jacobi, but kspSolve(kspA, bTmp, xTmp)
shows stagnation after about 3 iterations.
What can we do? Do think a good initial estimate for (x,y) helps?
Thanks a lot for any hints,
Kathrin
