[petsc-users] floating point exception… but only when >4 cores are used...
Andrew Spott andrew.spott at gmail.com
Sat Apr 28 20:16:52 CDT 2012
Yes it did… now I have a bunch of GDB windows open and ready, thanks.
-Andrew
On Apr 28, 2012, at 7:10 PM, Matthew Knepley wrote:
> On Sat, Apr 28, 2012 at 8:59 PM, Andrew Spott <andrew.spott at gmail.com> wrote:
> What makes it easier if autotools makes it hard?
> This is a joke, but I do think autotools makes everything hard.
> On Apr 28, 2012 6:43 PM, "Matthew Knepley" <knepley at gmail.com> wrote:
> On Sat, Apr 28, 2012 at 8:36 PM, Andrew Spott <andrew.spott at gmail.com> wrote:
> When I attach debugger on error on the local machine, I get a bunch of lines like this one:
> warning: Could not find object file "/private/tmp/homebrew-gcc-4.6.2-HNPr/gcc-4.6.2/build/x86_64-apple-darwin11.3.0/libstdc++-v3/src/../libsupc++/.libs/libsupc++convenience.a(cp-demangle.o)" - no debug information available for "cp-demangle.c".
> It looks like you build with autotools. That just makes things hard :)
> then ". done"  And then nothing.  It looks like the program exits before the debugger can attach.  after a while I get this:
> You can use -debugger_pause 10 to make it wait 10s before continuing after spawning the debugger. Make it long
> enough to attach.
> Did this work?
>    Matt
>    Matt
> /Users/spott/Documents/Code/EnergyBasisSchrodingerSolver/data/ebss-input/basis_rmax1.00e+02_rmin1.00e-06_dr1.00e-01/76151: No such file or directory
> Unable to access task for process-id 76151: (os/kern) failure.
> in the gdb window.  In the terminal window, I get
> application called MPI_Abort(MPI_COMM_WORLD, 0) - process 3
> [cli_3]: aborting job:
> if I just "start_in_debugger"  I just don't' get the "MPI_Abort" thing, but everything else is the same.
> any ideas?
> -Andrew
> On Apr 28, 2012, at 6:11 PM, Matthew Knepley wrote:
>> On Sat, Apr 28, 2012 at 8:07 PM, Andrew Spott <andrew.spott at gmail.com> wrote:
>> are there any tricks to doing this across ssh?
>> I've attempted it using the method given, but I can't get it to start in the debugger or to attach the debugger, the program just exits or hangs after telling me the error.
>> Is there a reason you cannot run this problem on your local machine with 4 processes?
>>    Matt
>> -Andrew
>> On Apr 28, 2012, at 4:45 PM, Matthew Knepley wrote:
>>> On Sat, Apr 28, 2012 at 6:39 PM, Andrew Spott <andrew.spott at gmail.com> wrote:
>>> >-start_in-debugger noxterm -debugger_nodes 14
>>> All my cores are on the same machine, is this supposed to start a debugger on processor 14? or computer 14?
>>> Neither. This spawns a gdb process on the same node as the process with MPI rank 14. Then attaches gdb
>>> to process 14.
>>>     Matt
>>> I don't think I have x11 setup properly for the compute nodes, so x11 isn't really an option.
>>> Thanks for the help.
>>> -Andrew
>>> On Apr 27, 2012, at 7:26 PM, Satish Balay wrote:
>>> > On Fri, 27 Apr 2012, Andrew Spott wrote:
>>> >> I'm honestly stumped.
>>> >> I have some petsc code that essentially just populates a matrix in parallel, then puts it in a file.  All my code that uses floating point computations is checked for NaN's and infinities and it doesn't seem to show up.  However, when I run it on more than 4 cores, I get floating point exceptions that kill the program.  I tried turning off the exceptions from petsc, but the program still dies from them, just without the petsc error message.
>>> >> I honestly don't know where to go, I suppose I should attach a debugger, but I'm not sure how to do that for multi-processor code.
>>> > assuming you have X11 setup properly from compute nodes you can run
>>> > with the extra option '-start_in_debugger'
>>> > If X11 is not properly setup - and you'd like to run gdb on one of the
>>> > nodes [say node 14 where you see SEGV] - you can do:
>>> > Or try valgrind
>>> > mpiexec -n 16 valgrind --tool=memcheck -q ./executable
>>> > For debugging - its best to install with --download-mpich [so that its
>>> > valgrind clean] - and run all mpi stuff on a single machine - [usually
>>> > X11 works well from a single machine.]
>>> > Satish
>>> >> any ideas?  (long error message below):
>>> >> -Andrew
>>> >> [14]PETSC ERROR: ------------------------------------------------------------------------
>>> >> [14]PETSC ERROR: Caught signal number 8 FPE: Floating Point Exception,probably divide by zero
>>> >> [14]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>> >> [14]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[14]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>> >> [14]PETSC ERROR: likely location of problem given in stack below
>>> >> [14]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
>>> >> [14]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>> >> [14]PETSC ERROR:       INSTEAD the line number of the start of the function
>>> >> [14]PETSC ERROR:       is given.
>>> >> [14]PETSC ERROR: --------------------- Error Message ------------------------------------
>>> >> [14]PETSC ERROR: Signal received!
>>> >> [14]PE[15]PETSC ERROR: ------------------------------------------------------------------------
>>> >> [15]PETSC ERROR: Caught signal number 8 FPE: Floating Point Exception,probably divide by zero
>>> >> [15]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>> >> [15]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[15]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>> >> [15]PETSC ERROR: likely location of problem given in stack below
>>> >> [15]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
>>> >> [15]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>> >> [15]PETSC ERROR:       INSTEAD the line number of the start of the function
>>> >> [15]PETSC ERROR:       is given.
>>> >> [15]PETSC ERROR: --------------------- Error Message ------------------------------------
>>> >> [15]PETSC ERROR: Signal received!
>>> >> [15]PETSC ERROR: Petsc Release Version 3.2.0, Patch 6, Wed Jan 11 09:28:45 CST 2012
>>> >> [14]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> >> [14]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> >> [14]PETSC ERROR: See docs/index.html for manual pages.
>>> >> [14]PETSC ERROR: /home/becker/ansp6066/local/bin/finddme on a linux-gnu named photon9.colorado.edu by ansp6066 Fri Apr 27 18:01:55 2012
>>> >> [14]PETSC ERROR: Libraries linked from /home/becker/ansp6066/local/petsc-3.2-p6/lib
>>> >> [14]PETSC ERROR: Configure run at Mon Feb 27 11:17:14 2012
>>> >> [14]PETSC ERROR: Configure options --prefix=/home/becker/ansp6066/local/petsc-3.2-p6 --with-c++-support --with-fortran --with-mpi-dir=/usr/local/mpich2 --with-shared-libraries=0 --with-scalar-type=complex --with-blas-lapack-libs=/central/intel/mkl/lib/em64t/libmkl_core.a --with-clanguage=cxx
>>> >> [14]TSC ERROR: Petsc Release Version 3.2.0, Patch 6, Wed Jan 11 09:28:45 CST 2012
>>> >> [15]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> >> [15]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> >> [15]PETSC ERROR: See docs/index.html for manual pages.
>>> >> [15]PETSC ERROR: /home/becker/ansp6066/local/bin/finddme on a linux-gnu named photon9.colorado.edu by ansp6066 Fri Apr 27 18:01:55 2012
>>> >> [15]PETSC ERROR: Libraries linked from /home/becker/ansp6066/local/petsc-3.2-p6/lib
>>> >> [15]PETSC ERROR: Configure run at Mon Feb 27 11:17:14 2012
>>> >> [15]PETSC ERROR: Configure options --prefix=/home/becker/ansp6066/local/petsc-3.2-p6 --with-c++-support --with-fortran --with-mpi-dir=/usr/local/mpich2 --with-shared-libraries=0 --with-scalar-type=complex --with-blas-lapack-libs=/central/intel/mkl/lib/em64t/libmkl_core.a --with-clanguage=cxx
>>> >> [15]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
>>> >> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 14PETSC ERROR: User provided function() line 0 in unknown directory unknown file
>>> >> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 15[0]0:Return code = 0, signaled with Interrupt
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
>> -- Norbert Wiener
> -- Norbert Wiener
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120428/48be9e38/attachment.htm>
