[petsc-users] floating point exception… but only when >4 cores are used...
Andrew Spott
andrew.spott at gmail.com
Sat Apr 28 17:39:32 CDT 2012
>-start_in-debugger noxterm -debugger_nodes 14
All my cores are on the same machine, is this supposed to start a debugger on processor 14? or computer 14?
I don't think I have x11 setup properly for the compute nodes, so x11 isn't really an option.
Thanks for the help.
-Andrew
On Apr 27, 2012, at 7:26 PM, Satish Balay wrote:
> On Fri, 27 Apr 2012, Andrew Spott wrote:
>> I'm honestly stumped.
>> I have some petsc code that essentially just populates a matrix in parallel, then puts it in a file. All my code that uses floating point computations is checked for NaN's and infinities and it doesn't seem to show up. However, when I run it on more than 4 cores, I get floating point exceptions that kill the program. I tried turning off the exceptions from petsc, but the program still dies from them, just without the petsc error message.
>> I honestly don't know where to go, I suppose I should attach a debugger, but I'm not sure how to do that for multi-processor code.
> assuming you have X11 setup properly from compute nodes you can run
> with the extra option '-start_in_debugger'
> If X11 is not properly setup - and you'd like to run gdb on one of the
> nodes [say node 14 where you see SEGV] - you can do:
> Or try valgrind
> mpiexec -n 16 valgrind --tool=memcheck -q ./executable
> For debugging - its best to install with --download-mpich [so that its
> valgrind clean] - and run all mpi stuff on a single machine - [usually
> X11 works well from a single machine.]
> Satish
>> any ideas? (long error message below):
>> -Andrew
>> [14]PETSC ERROR: ------------------------------------------------------------------------
>> [14]PETSC ERROR: Caught signal number 8 FPE: Floating Point Exception,probably divide by zero
>> [14]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [14]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[14]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>> [14]PETSC ERROR: likely location of problem given in stack below
>> [14]PETSC ERROR: --------------------- Stack Frames ------------------------------------
>> [14]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>> [14]PETSC ERROR: INSTEAD the line number of the start of the function
>> [14]PETSC ERROR: is given.
>> [14]PETSC ERROR: --------------------- Error Message ------------------------------------
>> [14]PETSC ERROR: Signal received!
>> [14]PE[15]PETSC ERROR: ------------------------------------------------------------------------
>> [15]PETSC ERROR: Caught signal number 8 FPE: Floating Point Exception,probably divide by zero
>> [15]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [15]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[15]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>> [15]PETSC ERROR: likely location of problem given in stack below
>> [15]PETSC ERROR: --------------------- Stack Frames ------------------------------------
>> [15]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>> [15]PETSC ERROR: INSTEAD the line number of the start of the function
>> [15]PETSC ERROR: is given.
>> [15]PETSC ERROR: --------------------- Error Message ------------------------------------
>> [15]PETSC ERROR: Signal received!
>> [15]PETSC ERROR: Petsc Release Version 3.2.0, Patch 6, Wed Jan 11 09:28:45 CST 2012
>> [14]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [14]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [14]PETSC ERROR: See docs/index.html for manual pages.
>> [14]PETSC ERROR: /home/becker/ansp6066/local/bin/finddme on a linux-gnu named photon9.colorado.edu by ansp6066 Fri Apr 27 18:01:55 2012
>> [14]PETSC ERROR: Libraries linked from /home/becker/ansp6066/local/petsc-3.2-p6/lib
>> [14]PETSC ERROR: Configure run at Mon Feb 27 11:17:14 2012
>> [14]PETSC ERROR: Configure options --prefix=/home/becker/ansp6066/local/petsc-3.2-p6 --with-c++-support --with-fortran --with-mpi-dir=/usr/local/mpich2 --with-shared-libraries=0 --with-scalar-type=complex --with-blas-lapack-libs=/central/intel/mkl/lib/em64t/libmkl_core.a --with-clanguage=cxx
>> [14]TSC ERROR: Petsc Release Version 3.2.0, Patch 6, Wed Jan 11 09:28:45 CST 2012
>> [15]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [15]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [15]PETSC ERROR: See docs/index.html for manual pages.
>> [15]PETSC ERROR: /home/becker/ansp6066/local/bin/finddme on a linux-gnu named photon9.colorado.edu by ansp6066 Fri Apr 27 18:01:55 2012
>> [15]PETSC ERROR: Libraries linked from /home/becker/ansp6066/local/petsc-3.2-p6/lib
>> [15]PETSC ERROR: Configure run at Mon Feb 27 11:17:14 2012
>> [15]PETSC ERROR: Configure options --prefix=/home/becker/ansp6066/local/petsc-3.2-p6 --with-c++-support --with-fortran --with-mpi-dir=/usr/local/mpich2 --with-shared-libraries=0 --with-scalar-type=complex --with-blas-lapack-libs=/central/intel/mkl/lib/em64t/libmkl_core.a --with-clanguage=cxx
>> [15]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 14PETSC ERROR: User provided function() line 0 in unknown directory unknown file
>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 15[0]0:Return code = 0, signaled with Interrupt
