[petsc-users] Efficient Block Matrix implementation
Matthew Knepley
knepley at gmail.com
Fri Apr 27 15:04:21 CDT 2012
On Fri, Apr 27, 2012 at 3:50 PM, <tibo at berkeley.edu> wrote:
> Hi,
> I am using petsc in a Fortran code to solve large systems of linear
> equations Ax = b where A is a matrix resulting from a discretization of a
> reaction diffusion problem: A is block-tridiagonal, and each of the three
> blocks is sparse. It turns out that I know exactly the sparsity structure
> of each block (ie the number and position of non-zeros per row).
> For now, I am only writing a sequential code. From the petsc manual, it
> seems there are two ways to create my matrix A: Either using
> MatCreateSeqAIJ, or using MatCreateSeqBAIJ. The second approach seems
> recommended since A is indeed a Block matrix.
> However, the command MatCreateSeqAIJ allows me to specify the number of
> non zeros per row, therefore allowing me to take advantage of knowing the
> sparsity structure of my blocks (but losing the advantage of using the
> fact that the matrix is a block matrix). It seems that the command
> MatCreateSeqBAIJ only allows me to specify the number of non zeros blocks
> per block rows, therefore losing the available information on the sparsity
> of each block.
> My question is then: Is there a way to declare the matrix to take
> advantage of both the fact that my matrix is a block matrix (or even
> better, that it is a block tridiagonal matrix) and that I know the
> sparsity structure of the blocks ?
What exactly do you want to do with the blocks? Its easy to extract them
with
MatGetSubmatrix() and they can be used in the PCFIELDSPLIT preconditioner.
Matt
> I am asking this question because If I use the block matrix approach as
> described above (just specifying the number of non zeros blocks per block
> rows) versus the AIJ approach with specifying the number of non zeros for
> each row, the computing time increases by a factor of 5, every other
> parameters being unchanged.
> Thank you
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120427/ec6ba85d/attachment-0001.htm>
