[petsc-users] Problem with fortran version of ex29 in ksp
TAY wee-beng zonexo at gmail.com
Thu Apr 26 17:21:00 CDT 2012
I managed to remove the out of range error by removing
*num = num + 1* from
col(MatStencil_i,num) = i
                 col(MatStencil_j,num) = j+1
*num = num + 1*
                 call
MatSetValuesStencil(jac,i1,row,num,col,v,INSERT_VALUES,ierr)
In C, num will give the number 5 since num start from 0.
In fortran, num starts from 1 so num = num + 1 before
MatSetValuesStencil must be removed.
I still can't get the same ans. I will try to figure it out. Just to
confirm, this subroutine:
call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
is not added in fortran, although it is used in C.
Yours sincerely,
TAY wee-beng
On 26/4/2012 9:29 PM, Matthew Knepley wrote:
> On Thu, Apr 26, 2012 at 3:26 PM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi,
>     Thanks for pointing out my mistake. I'm still learning about the
>     code. I corrected but I still get the error:
> I am sure its another simple bug. Go in with the debugger. When it
> says you are inserting a new nonzero,
> back up the stack to your routine and see what indices you are tying
> to insert. If its not part of the stencil,
> you have found the bug.
>   Matt
>     [0]PETSC ERROR: --------------------- Error Message
>     [0]PETSC ERROR: Argument out of range!
>     [0]PETSC ERROR: New nonzero at (2,4) caused a malloc!
>     [0]PETSC ERROR:
>     boundary condition region:
>     num = 1
>                     if (j/=0) then
>                         v(num) = -rho*HxdHy
>                         col(MatStencil_j,num) = j-1
>                         num = num + 1
>                     end if
>                     if (i/=0) then
>                         v(num) = -rho*HydHx
>                         col(MatStencil_i,num) = i-1
>                         num = num + 1
>                     end if
>                     if (i/=mx-1) then
>                         v(num) = -rho*HydHx
>                         col(MatStencil_i,num) = i+1
>                         num = num + 1
>                     end if
>                     if (j/=my-1) then
>                         v(num) = -rho*HxdHy
>                         num = num + 1
>                     end if
>                     v(num) = (num/2.0)*rho*(HxdHy + HydHx)
>                     num = num + 1
>                     call
>     Yours sincerely,
>     TAY wee-beng
>     On 26/4/2012 2:45 PM, Matthew Knepley wrote:
>>     On Thu, Apr 26, 2012 at 8:27 AM, TAY wee-beng <zonexo at gmail.com
>>         Hi,
>>         Is there an answer to the question below?
>>          I still can't get it working.
>>         Thanks.
>>         Hi,
>>         There's no error now but I didn't get the same ans as ex29. I
>>         believe the error lies in the boundary evaluation of v.
>>         In c, the code is :
>>         else if (user->bcType == NEUMANN) {
>>                   num = 0;
>>                   if (j!=0) {
>>                     v[num] = -rho*HxdHy;              col[num].i =
>>         i;   col[num].j = j-1;
>>     ^^^ See this?
>>                     num++;
>>                   if (i!=0) {
>>                     v[num] = -rho*HydHx;              col[num].i =
>>         i-1; col[num].j = j;
>>                     num++;
>>                   if (i!=mx-1) {
>>         i+1; col[num].j = j;
>>                     num++;
>>                   if (j!=my-1) {
>>         i;   col[num].j = j+1;
>>                     num++;
>>                   v[num]   = (num/2.0)*rho*(HxdHy + HydHx);
>>         col[num].i = i;   col[num].j = j;
>>                   num++;
>>                   ierr =
>>         MatSetValuesStencil(jac,1,&row,num,col,v,INSERT_VALUES);CHKERRQ(ierr);
>>         In fortran, I have changed to :
>>         else if (bc_cond == 2) then
>>                         num = 1
>>                         if (j/=0) then
>>                             v(num) = -rho*HxdHy
>>                             col(MatStencil_i,1) = i
>>                                                    ^^ Why is this 1
>>     in stead of 'num'?
>>        Matt
>>                             col(MatStencil_j,2) = j-1
>>                             num = num + 1
>>                         end if
>>                         if (i/=0) then
>>                             v(num) = -rho*HydHx
>>                             col(MatStencil_i,1) = i-1
>>                             num = num + 1
>>                         end if
>>                         if (i/=mx-1) then
>>                             v(num) = -rho*HydHx
>>                             col(MatStencil_i,1) = i+1
>>                             num = num + 1
>>                         end if
>>                         if (j/=my-1) then
>>                             v(num) = -rho*HxdHy
>>                             col(MatStencil_j,2) = j+1
>>                             num = num + 1
>>                         end if
>>                         num = num + 1
>>                         call
>>         However, I got the error:
>>         [0]PETSC ERROR: New nonzero at (1,3) caused a malloc!
>>         [0]PETSC ERROR:
>>         How such is be defined in Fortran?
>>         Thank you
>>         Yours sincerely,
>>         TAY wee-beng
>>         On 25/4/2012 12:06 AM, Matthew Knepley wrote:
>>>         On Tue, Apr 24, 2012 at 4:57 PM, TAY wee-beng
>>>         <zonexo at gmail.com <mailto:zonexo at gmail.com>> wrote:
>>>             Hi,
>>>             I still got the same error the moment this subroutine is
>>>             called, after changing to :
>>>             call
>>>             MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,PETSC_NULL_INTEGER,PETSC_NULL_OBJECT,nullspace,ierr)
>>>         Argument 3 should be 0.
>>>           Matt
>>>             [0]PETSC ERROR: Null argument, when expecting valid pointer!
>>>             [0]PETSC ERROR: Null Object: Parameter # 4!
>>>             [0]PETSC ERROR:
>>>             [0]PETSC ERROR: Petsc Development HG revision:
>>>             fc934c1d84bc6ba8e2686702a8a99539d
>>>             50af122  HG Date: Mon Apr 23 11:39:32 2012 -0500
>>>             [0]PETSC ERROR: See docs/changes/index.html for recent
>>>             updates.
>>>             [0]PETSC ERROR: See docs/faq.html for hints about
>>>             trouble shooting.
>>>             [0]PETSC ERROR: See docs/index.html for manual pages.
>>>             [0]PETSC ERROR:
>>>             [0]PETSC ERROR: c:\obj_tmp\ex29f\Debug\ex29f.exe on a
>>>             petsc-3.2 named USER-PC by
>>>              User Tue Apr 24 22:54:50 2012
>>>             [0]PETSC ERROR: Libraries linked from
>>>             /cygdrive/d/Lib/petsc-3.2-dev_win32_vs2008
>>>             /lib
>>>             [0]PETSC ERROR: Configure run at Mon Apr 23 21:45:20 2012
>>>             [0]PETSC ERROR: Configure options --with-cc="win32fe cl"
>>>             --with-fc="win32fe ifor
>>>             t" --with-cxx="win32fe cl"
>>>             --with-mpi-dir=/cygdrive/d/Lib/MPICH2/ --download-f-b
>>>             las-lapack=1
>>>             --prefix=/cygdrive/d/Lib/petsc-3.2-dev_win32_vs2008
>>>             --with-debuggin
>>>             g=1 --useThreads=0
>>>             [0]PETSC ERROR:
>>>             [0]PETSC ERROR: MatNullSpaceCreate() line 250 in
>>>             src/mat/interface/C:\temp\PETSC
>>>             -~1\src\mat\INTERF~1\matnull.c
>>>             Yours sincerely,
>>>             TAY wee-beng
>>>             On 24/4/2012 10:37 PM, Matthew Knepley wrote:
>>>>             On Tue, Apr 24, 2012 at 4:32 PM, TAY wee-beng
>>>>                 Hi,
>>>>                 I'm trying to rewrite ex29 (KSP^Laplacian, 2d) from
>>>>                 c to fortran version. The fortran version is based
>>>>                 on the template of ex22f, which is in 3d.
>>>>                 I have attached the code below. I have 2 problems.
>>>>                 1. When i3 = -3, in dirichlet BC, I got the same
>>>>                 answer as ex29 in c version.
>>>>                 However, when I change i3 to -4, I got the
>>>>                 following error:
>>>>                 [0]PETSC ERROR: New nonzero at (9,1) caused a malloc!
>>>>                 [0]PETSC ERROR:
>>>>                 recent updates.
>>>>                 trouble shooting.
>>>>                 [0]PETSC ERROR:
>>>>                 a petsc-3.2 named USER-PC by
>>>>                  User Tue Apr 24 22:08:46 2012
>>>>                 /lib
>>>>                 21:45:20 2012
>>>>                 --with-cc="win32fe cl" --with-fc="win32fe ifor
>>>>                 las-lapack=1
>>>>                 --with-debuggin
>>>>                 g=1 --useThreads=0
>>>>                 [0]PETSC ERROR:
>>>>                 [0]PETSC ERROR: MatSetValues_SeqAIJ() line 331 in
>>>>                 src/mat/impls/aij/seq/C:\temp\
>>>>                 PETSC-~1\src\mat\impls\aij\seq\aij.c
>>>>                 [0]PETSC ERROR: MatSetValues() line 1148 in
>>>>                 src/mat/interface/C:\temp\PETSC-~1\s
>>>>                 rc\mat\INTERF~1\matrix.c
>>>>                 [0]PETSC ERROR: MatSetValuesLocal() line 2003 in
>>>>                 -~1\src\mat\INTERF~1\matrix.c
>>>>                 [0]PETSC ERROR: MatSetValuesStencil() line 1379 in
>>>>                 SC-~1\src\mat\INTERF~1\matrix.c
>>>>                 [0]PETSC ERROR: New nonzero at (10,2) caused a malloc!
>>>>                 What did I do wrong?
>>>>                 2. When I wanted to use the neumann BC, following
>>>>                 ex29, I added :
>>>>                 In subroutine ComputeRHS
>>>>                 call
>>>>                 MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,nullspace,ierr)
>>>>                 call MatNullSpaceDestroy(nullspace,ierr)
>>>>                 and in subroutine ComputeMatrix
>>>>                 call
>>>>                 call MatSetNullSpace(jac,nullspace,ierr)
>>>>                 When I compile, it says unresolved external symbol
>>>>                 MatNullSpaceRemove. Removing MatNullSpaceRemove, I
>>>>                 can compile but running gives the error:
>>>>                 [0]PETSC ERROR: Corrupt argument:
>>>>                 see
>>>>                 http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind!
>>>>                 [0]PETSC ERROR: Invalid Pointer to Object:
>>>>                 Parameter # 4!
>>>>                 [0]PETSC ERROR:
>>>>                 recent updates.
>>>>                 trouble shooting.
>>>>                 [0]PETSC ERROR:
>>>>                  User Tue Apr 24 22:30:31 2012
>>>>                 /lib
>>>>                 21:45:20 2012
>>>>                 las-lapack=1
>>>>                 --with-debuggin
>>>>                 g=1 --useThreads=0
>>>>                 [0]PETSC ERROR:
>>>>                 [0]PETSC ERROR: Invalid argument!
>>>>                 [0]PETSC ERROR: Wrong type of object: Parameter # 1!
>>>>                 [0]PETSC ERROR:
>>>>                 recent updates.
>>>>                 trouble shooting.
>>>>                 [0]PETSC ERROR:
>>>>                 /lib
>>>>                 21:45:20 2012
>>>>                 las-lapack=1
>>>>                 --with-debuggin
>>>>                 g=1 --useThreads=0
>>>>                 [0]PETSC ERROR:
>>>>                 [0]PETSC ERROR: MatNullSpaceDestroy() line 305 in
>>>>                 C-~1\src\mat\INTERF~1\matnull.c
>>>>                 [0]PETSC ERROR: ourdmfunction() line 30 in
>>>>                 src/dm/interface/ftn-custom/C:\temp\P
>>>>                 ETSC-~1\src\dm\INTERF~1\FTN-CU~1\zdmf.c
>>>>                 [0]PETSC ERROR: DMComputeFunction() line 1783 in
>>>>                 src/dm/interface/C:\temp\PETSC-
>>>>                 ~1\src\dm\INTERF~1\dm.c
>>>>                 [0]PETSC ERROR: KSPSetUp() line 218 in
>>>>                 src/ksp/ksp/interface/C:\temp\PETSC-~1\sr
>>>>                 c\ksp\ksp\INTERF~1\itfunc.c
>>>>                 see
>>>>                 Parameter # 4!
>>>>                 [0]PETSC ERROR:
>>>>                 recent updates.
>>>>                 trouble shooting.
>>>>                 [0]PETSC ERROR:
>>>>                 /lib
>>>>                 21:45:20 2012
>>>>                 las-lapack=1
>>>>                 --with-debuggin
>>>>                 g=1 --useThreads=0
>>>>                 [0]PETSC ERROR:
>>>>                 [0]PETSC ERROR:
>>>>                 recent updates.
>>>>                 trouble shooting.
>>>>                 [0]PETSC ERROR:
>>>>                 /lib
>>>>                 21:45:20 2012
>>>>                 las-lapack=1
>>>>                 --with-debuggin
>>>>                 g=1 --useThreads=0
>>>>                 [0]PETSC ERROR:
>>>>                 [0]PETSC ERROR: KSPSolve() line 402 in
>>>>                 Vector Object:Vec_0000000084000000_0 1 MPI processes
>>>>                   type: mpi
>>>>                 Process [0]
>>>>                 What's wrong?
>>>>                 *program ex29f*
>>>>                 implicit none
>>>>                 !                    Include files
>>>>                 !     petscsys.h  - base PETSc routines
>>>>                 petscvec.h - vectors
>>>>                 !     petscmat.h - matrices
>>>>                 !     petscksp.h    - Krylov subspace methods
>>>>                 petscpc.h  - preconditioners
>>>>                 #include "finclude/petsc.h90"
>>>>                 PetscErrorCode   ierr
>>>>                 DM               da
>>>>                 KSP              ksp
>>>>                 Vec              x
>>>>                 external         ComputeRHS,ComputeMatrix
>>>>                 PetscInt i1,i3
>>>>                 call  PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>>>>                 i3 = -4
>>>>                 i1 = 1
>>>>                 call KSPCreate(MPI_COMM_WORLD,ksp,ierr)
>>>>                 call
>>>>                 DMDACreate2d(PETSC_COMM_WORLD,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_STENCIL_STAR,i3,i3,PETSC_DECIDE,PETSC_DECIDE,i1,i1,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da,ierr)
>>>>                 call DMSetFunction(da,ComputeRHS,ierr)
>>>>                 call DMSetJacobian(da,ComputeMatrix,ierr)
>>>>                 call KSPSetDM(ksp,da,ierr)
>>>>                 call KSPSetFromOptions(ksp,ierr)
>>>>                 call KSPSetUp(ksp,ierr)
>>>>                 call
>>>>                 KSPSolve(ksp,PETSC_NULL_OBJECT,PETSC_NULL_OBJECT,ierr)
>>>>                 call KSPGetSolution(ksp,x,ierr)
>>>>                 call VecView(x,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>>>                 call KSPDestroy(ksp,ierr)
>>>>                 call DMDestroy(da,ierr)
>>>>                 call PetscFinalize(ierr)
>>>>                 end program ex29f
>>>>                 subroutine ComputeRHS(da,x,b,ierr)
>>>>                 implicit none
>>>>                 PetscErrorCode  ierr
>>>>                 PetscInt i,j,mx,my,xm,ym,xs,ys
>>>>                 PetscScalar  h,nu,rho
>>>>                 PetscScalar Hx,Hy
>>>>                 PetscScalar,pointer :: array(:,:)
>>>>                 Vec          x,b
>>>>                 DM           da
>>>>                 MatNullSpace nullspace    !>neumann BC
>>>>                 nu = 0.1
>>>>                 call
>>>>                 DMDAGetInfo(da,PETSC_NULL_INTEGER,mx,my,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,ierr)
>>>>                 Hx = 1.d0 / (mx-1)
>>>>                 Hy = 1.d0 / (my-1)
>>>>                 call
>>>>                 DMDAGetCorners(da,xs,ys,PETSC_NULL_INTEGER,xm,ym,PETSC_NULL_INTEGER,ierr)
>>>>                 call DMDAVecGetArrayF90(da,b,array,ierr)
>>>>                 do j = ys,ys+ym-1
>>>>                     do i = xs,xs+xm-1
>>>>                         array(i,j) =
>>>>                 exp(-(i*Hx)*(i*Hx)/nu)*exp(-(j*Hy)*(j*Hy)/nu)*Hx*Hy
>>>>                     end do
>>>>                 end do
>>>>                 call DMDAVecRestoreArrayF90(da,b,array,ierr)
>>>>                 call VecAssemblyBegin(b,ierr)
>>>>                 call VecAssemblyEnd(b,ierr)
>>>>                 !call
>>>>             4th argument should be PETSC_NULL_OBJECT.
>>>>                Matt
>>>>                 !call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
>>>>                 !call MatNullSpaceDestroy(nullspace,ierr)
>>>>                 end subroutine ComputeRHS
>>>>                 subroutine ComputeMatrix(da,x,JJ,jac,str,ierr)
>>>>                 implicit none
>>>>                 Mat          jac,JJ
>>>>                 PetscErrorCode    ierr
>>>>                 DM           da
>>>>                 PetscInt    i,j,k,mx,my,xm
>>>>                 PetscInt    ym,xs,ys,i1,i5
>>>>                 PetscScalar  v(5),Hx,Hy,rho,centerRho
>>>>                 PetscScalar  HydHx
>>>>                 PetscScalar  HxdHy
>>>>                 MatStencil   row(4),col(4,5)
>>>>                 Vec          x
>>>>                 MatStructure str
>>>>                 rho = 1.0
>>>>                 i1 = 1
>>>>                 i5 = 5
>>>>                 centerRho = rho
>>>>                 call
>>>>                 Hx = 1.d0 / (mx-1)
>>>>                 Hy = 1.d0 / (my-1)
>>>>                 HxdHy = Hx/Hy
>>>>                 HydHx = Hy/Hx
>>>>                 call
>>>>                 do j=ys,ys+ym-1
>>>>                     do i=xs,xs+xm-1
>>>>                         row(MatStencil_i) = i
>>>>                         row(MatStencil_j) = j
>>>>                         call ComputeRho(i,j,mx,my,centerRho,rho)
>>>>                         if (i.eq.0 .or. j.eq.0 .or. i.eq.mx-1 .or.
>>>>                 j.eq.my-1) then
>>>>                             v(1) = 2.0*rho*(HxdHy + HydHx)
>>>>                             call
>>>>                 MatSetValuesStencil(jac,i1,row,i1,row,v,INSERT_VALUES,ierr)
>>>>                         else
>>>>                             v(1) = -rho*HxdHy
>>>>             Cut and paste error above.
>>>>               Matt
>>>>                             v(2) = -rho*HydHx
>>>>                             col(MatStencil_i,2) = i-1
>>>>                             v(3) = 2.0*rho*(HxdHy + HydHx)
>>>>                             col(MatStencil_i,3) = i
>>>>                             col(MatStencil_j,3) = j
>>>>                             v(4) = -rho*HydHx
>>>>                             col(MatStencil_i,4) = i+1
>>>>                             col(MatStencil_j,4) = j
>>>>                             v(5) = -rho*HxdHy
>>>>                             col(MatStencil_i,5) = i
>>>>                             col(MatStencil_j,5) = j+1
>>>>                             call
>>>>                 MatSetValuesStencil(jac,i1,row,i5,col,v,INSERT_VALUES,ierr)
>>>>                         end if
>>>>                     end do
>>>>                 end do
>>>>                 call MatAssemblyBegin(jac,MAT_FINAL_ASSEMBLY,ierr)
>>>>                 call MatAssemblyEnd(jac,MAT_FINAL_ASSEMBLY,ierr)
>>>>                 !call
>>>>                 !call MatSetNullSpace(jac,nullspace,ierr)
>>>>                 end subroutine ComputeMatrix
>>>>                 subroutine ComputeRho(i,j,mx,my,centerRho,rho)
>>>>                 PetscInt    i,j,mx,my
>>>>                 PetscScalar  rho,centerRho
>>>>                 if ((i > mx/3.0) .and. (i < 2.0*mx/3.0) .and. (j >
>>>>                 my/3.0) .and. (j < 2.0*my/3.0)) then
>>>>                     rho = centerRho
>>>>                 else
>>>>                     rho = 1.0
>>>>                 end if
>>>>                 end subroutine ComputeRho
>>>>                 Yours sincerely,
>>>>                 TAY wee-beng
>>>>             What most experimenters take for granted before they
>>>>             begin their experiments is infinitely more interesting
>>>>             than any results to which their experiments lead.
>>>>             -- Norbert Wiener
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120427/502a644b/attachment-0001.htm>
