[petsc-users] MatCreateMPIAIJ with zero size on some ranks
    Matthew Knepley
    knepley at gmail.com
    Wed Apr 25 06:51:33 CDT 2012
On Wed, Apr 25, 2012 at 7:42 AM, Thomas Witkowski <
thomas.witkowski at tu-dresden.de> wrote:
>  Am 25.04.2012 13:21, schrieb Jed Brown:
> On Wed, Apr 25, 2012 at 02:21, Thomas Witkowski <
>> Is it possible to create a parallel matrix (MPIAIJ) with empty size on
>> some ranks? Even if this should work, does it make sense (with respect to
>> runtime and efficiency) to collect all ranks having a nonempty contribution
>> the the global matrix in an mpi group and to use this communicator for
>> matrix create/computations?
> It depends how many ranks are empty. For coarse levels of multigrid (where
> this situation arises frequently), it's sometimes worthwhile to also move
> the data to a part of the machine that is topologically "close".
> Identifying "closeness" is not always easy because MPI does not necessarily
> expose this information in a useful fashion.
>  What is the circumstance where this occurs for you?
> Also some coarse space method. When not all ranks contribute to the coarse
> space, a matrix defined on the coarse space leads to local empty matrices
> on these ranks. So the question is if this leads to technical troubles in
> PETSc. The share of nodes participating in the coarse space may vary.
No
  Matt
> Thomas
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120425/ef392618/attachment.htm>
