[petsc-users] error in petsc-dev
Hong Zhang hzhang at mcs.anl.gov
Tue Apr 24 19:58:02 CDT 2012
Mohammad :
> Is this also true with MatSetType()? petsc-dev seems to need it (3.2-p6
> does not) but it's not listed in the changes link ...
There is no change on  MatSetType(). The default type is aij.
You can check petsc examples,
e.g. petsc-dev/src/ksp/ksp/examples/tutorials/ex2.c
Hong
> On Tue, Apr 24, 2012 at 4:27 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>> Thanks Hong.
>> On Tue, Apr 24, 2012 at 4:25 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
>>> See
>>> http://www.mcs.anl.gov/petsc/documentation/changes/dev.html:
>>> You MUST now call MatXXXSetPreallocation() or MatSetUp() on any matrix
>>> you create directly (not using DMCreateMatrix()) before calling
>>> MatSetValues(), MatSetValuesBlocked() etc.
>>> On Tue, Apr 24, 2012 at 6:01 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>>>> Hi,
>>>> While trying to figure out a problem, I came across the following
>>>> situation. Consider the following code:
>>>> int main (int argc, char **argv){
>>>>     PetscInitialize(&argc, &argv, (char*)0, help);
>>>>     Mat m;
>>>>     MatCreate(PETSC_COMM_WORLD, &m);
>>>>     MatSetSizes(m, 10, 10, PETSC_DECIDE, PETSC_DECIDE);
>>>>     MatSetFromOptions(m);
>>>>     MatAssemblyBegin(m, MAT_FINAL_ASSEMBLY);
>>>>     MatAssemblyEnd(m, MAT_FINAL_ASSEMBLY);
>>>>     MatView(m, PETSC_VIEWER_STDOUT_WORLD);
>>>>     MatDestroy(&m);
>>>>     PetscFinalize();
>>>>     return 0;
>>>> This runs without any problem under 3.2-p6 but fails with petsc-dev:
>>>> [0]PETSC ERROR: --------------------- Error Message
>>>> [0]PETSC ERROR: Object is in wrong state!
>>>> [0]PETSC ERROR: Must call MatXXXSetPreallocation() or MatSetUp() on
>>>> argument 1 "mat" before MatAssemblyBegin()!
>>>> [0]PETSC ERROR:
>>>> Eventually I could fix this by adding MatSetUp(m) after setting the
>>>> options. Why do I need this in petsc-dev? Does this somehow preallocate the
>>>> matrix?
>>> Yes.
>>> Hong
>>>> Thanks,
>>>> Mohammad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120424/90844ed2/attachment-0001.htm>
