[petsc-users] Questions abt ex22f
Matthew Knepley
knepley at gmail.com
Sun Apr 22 14:28:39 CDT 2012
On Sun, Apr 22, 2012 at 3:20 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Look at the man page for VecView, it needs a PetscViewer argument.
Works for me with VecView(x, PETSC_NULL_OBJECT, ierr), although it is 0
Matt
> On Apr 22, 2012 2:19 PM, "TAY wee-beng" <zonexo at gmail.com> wrote:
>> Hi,
>> I have attached the ex22f.F file. The changes I added are given in bold:
>> PetscErrorCode ierr
>> DM da
>> KSP ksp
>> * Vec x,b*
>> external ComputeRHS,ComputeMatrix
>> call KSPSetUp(ksp,ierr)
>> call KSPSolve(ksp,PETSC_NULL_OBJECT,PETSC_NULL_OBJECT,ierr)
>> *call KSPGetSolution(ksp,x,ierr)
>> call VecView(x,ierr)*
>> call KSPDestroy(ksp,ierr)
>> call DMDestroy(da,ierr)
>> The error is:
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> probably memory access out of range
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [0]PETSC ERROR: or see
>> http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC
>> ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
>> find memory corruption errors
>> [0]PETSC ERROR: likely location of problem given in stack below
>> [0]PETSC ERROR: --------------------- Stack Frames
>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>> available,
>> [0]PETSC ERROR: INSTEAD the line number of the start of the function
>> [0]PETSC ERROR: is given.
>> [0]PETSC ERROR: [0] VecView line 735
>> /home/wtay/Codes/petsc-3.2-p5/src/vec/vec/interface/vector.c
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Signal received!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29 13:45:54
>> CDT 2011
>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: ./ex22f on a arch-linu named hpc12 by wtay Sun Apr 22
>> 21:11:39 2012
>> [0]PETSC ERROR: Libraries linked from
>> /home/wtay/Lib/petsc-3.2-p5_mumps_debug/lib
>> [0]PETSC ERROR: Configure run at Sun Nov 27 15:39:26 2011
>> [0]PETSC ERROR: Configure options --with-mpi-dir=/opt/openmpi-1.5.3/
>> --with-blas-lapack-dir=/opt/intel_xe_2011/mkl/lib/intel64/
>> --with-debugging=1 --download-hypre=1
>> --prefix=/home/wtay/Lib/petsc-3.2-p5_mumps_debug COPTFLAGS=-O0
>> FOPTFLAGS=-O0 --download-mumps=1 --download-parmetis=1
>> --download-scalapack=1 --download-blacs=1
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: User provided function() line 0 in unknown directory
>> unknown file
>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>> with errorcode 59.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> Yours sincerely,
>> TAY wee-beng
>> On 22/4/2012 9:06 PM, Jed Brown wrote:
>> Run in a debugger and/or use --with-debugging=1 so that the error trace
>> has more information. You could also show us the exact code that you used.
>> On Apr 22, 2012 2:03 PM, "TAY wee-beng" <zonexo at gmail.com> wrote:
>>> Hi,
>>> I added "Vec x,b" after "KSP ksp"
>>> and then "call KSPGetSolution(ksp, x, ierr)"
>>> I wanted to see the output so I added "call VecView(x,ierr)" but I got
>>> this error:
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
>>> and run
>>> [0]PETSC ERROR: to get more information on the crash.
>>> [0]PETSC ERROR:
>>> 13:45:54 CDT 2011
>>> [0]PETSC ERROR:
>>> 21:02:14 2012
>>> /home/wtay/Lib/petsc-3.2-p5_mumps_rel/lib
>>> [0]PETSC ERROR: Configure run at Sun Nov 27 15:18:15 2011
>>> --with-debugging=0 --download-hypre=1
>>> --prefix=/home/wtay/Lib/petsc-3.2-p5_mumps_rel COPTFLAGS=-O3 FOPTFLAGS=-O3
>>> --download-mumps=1 --download-parmetis=1 --download-scalapack=1
>>> --download-blacs=1
>>> [0]PETSC ERROR:
>>> unknown file
>>> with errorcode 59.
>>> Yours sincerely,
>>> TAY wee-beng
>>> On 22/4/2012 2:53 PM, Matthew Knepley wrote:
>>> On Sun, Apr 22, 2012 at 3:31 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>> Hi,
>>>> I am using petsc-dev 2012-04-20.
>>>> Btw, I'm referring to :
>>>> http://www.mcs.anl.gov/petsc/petsc-dev/src/ksp/ksp/examples/tutorials/ex22f.F.html
>>>> Part of the code is :
>>>> call KSPSetFromOptions(ksp,ierr)
>>>> call PetscFinalize(ierr)
>>>> Unlike other codes like ex29c or ex45c, there isn't a "call
>>>> KSPGetSolution(ksp,x,ierr)"
>>> You need to declare "Vec x", and then you can call KSPGetSolution(ksp,
>>> x, ierr)
>>> Matt
>>>> Also I want to add "call VecView(x,ierr)" to print out the results,
>>>> which is usally added after the above.
>>>> Thank you
>>>> Yours sincerely,
>>>> TAY wee-beng
>>>> On 22/4/2012 1:14 AM, Matthew Knepley wrote:
>>>> On Sat, Apr 21, 2012 at 6:31 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>>> Hi,
>>>>> May I know if ex22f is complete? I can't find :
>>>>> If I entered it, it says x not found.
>>>> This is correct in petsc-dev. What version are you using?
>>>> Thanks,
>>>> Matt
>>>>> Thank you!
>>>>> Yours sincerely,
>>>>> TAY wee-beng
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120422/7fad2d54/attachment-0001.htm>
