[petsc-users] Questions abt ex22f
Jed Brown
jedbrown at mcs.anl.gov
Sun Apr 22 14:06:47 CDT 2012
Run in a debugger and/or use --with-debugging=1 so that the error trace has
more information. You could also show us the exact code that you used.
On Apr 22, 2012 2:03 PM, "TAY wee-beng" <zonexo at gmail.com> wrote:
> Hi,
> I added "Vec x,b" after "KSP ksp"
> and then "call KSPGetSolution(ksp, x, ierr)"
> I wanted to see the output so I added "call VecView(x,ierr)" but I got
> this error:
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC
> ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find
> memory corruption errors
> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
> run
> [0]PETSC ERROR: to get more information on the crash.
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29 13:45:54
> CDT 2011
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./ex22f on a arch-linu named hpc12 by wtay Sun Apr 22
> 21:02:14 2012
> [0]PETSC ERROR: Libraries linked from
> /home/wtay/Lib/petsc-3.2-p5_mumps_rel/lib
> [0]PETSC ERROR: Configure run at Sun Nov 27 15:18:15 2011
> [0]PETSC ERROR: Configure options --with-mpi-dir=/opt/openmpi-1.5.3/
> --with-blas-lapack-dir=/opt/intel_xe_2011/mkl/lib/intel64/
> --with-debugging=0 --download-hypre=1
> --prefix=/home/wtay/Lib/petsc-3.2-p5_mumps_rel COPTFLAGS=-O3 FOPTFLAGS=-O3
> --download-mumps=1 --download-parmetis=1 --download-scalapack=1
> --download-blacs=1
> [0]PETSC ERROR:
> [0]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 59.
> Yours sincerely,
> TAY wee-beng
> On 22/4/2012 2:53 PM, Matthew Knepley wrote:
> On Sun, Apr 22, 2012 at 3:31 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi,
>> I am using petsc-dev 2012-04-20.
>> Btw, I'm referring to :
>> http://www.mcs.anl.gov/petsc/petsc-dev/src/ksp/ksp/examples/tutorials/ex22f.F.html
>> Part of the code is :
>> call KSPSetFromOptions(ksp,ierr)
>> call KSPSetUp(ksp,ierr)
>> call KSPSolve(ksp,PETSC_NULL_OBJECT,PETSC_NULL_OBJECT,ierr)
>> call KSPDestroy(ksp,ierr)
>> call DMDestroy(da,ierr)
>> call PetscFinalize(ierr)
>> Unlike other codes like ex29c or ex45c, there isn't a "call
>> KSPGetSolution(ksp,x,ierr)"
> You need to declare "Vec x", and then you can call KSPGetSolution(ksp,
> x, ierr)
> Matt
>> Also I want to add "call VecView(x,ierr)" to print out the results,
>> which is usally added after the above.
>> Thank you
>> Yours sincerely,
>> TAY wee-beng
>> On 22/4/2012 1:14 AM, Matthew Knepley wrote:
>> On Sat, Apr 21, 2012 at 6:31 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>> Hi,
>>> May I know if ex22f is complete? I can't find :
>>> call KSPGetSolution(ksp,x,ierr)
>>> If I entered it, it says x not found.
>> This is correct in petsc-dev. What version are you using?
>> Thanks,
>> Matt
>>> Thank you!
>>> Yours sincerely,
>>> TAY wee-beng
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120422/faa2d036/attachment.htm>
