[petsc-users] Questions abt ex22f
TAY wee-beng zonexo at gmail.com
Sun Apr 22 02:31:29 CDT 2012
I am using petsc-dev 2012-04-20.
Btw, I'm referring to :
http://www.mcs.anl.gov/petsc/petsc-dev/src/ksp/ksp/examples/tutorials/ex22f.F.html
Part of the code is :
call KSPSetFromOptions(ksp,ierr)
       call KSPSetUp(ksp,ierr)
       call KSPSolve(ksp,PETSC_NULL_OBJECT,PETSC_NULL_OBJECT,ierr)
       call KSPDestroy(ksp,ierr)
       call DMDestroy(da,ierr)
       call PetscFinalize(ierr)
Unlike other codes like ex29c or ex45c, there isn't a "call
KSPGetSolution(ksp,x,ierr)"
Also I want to add "call VecView(x,ierr)" to print out the results,
which is usally added after the above.
Thank you
Yours sincerely,
TAY wee-beng
On 22/4/2012 1:14 AM, Matthew Knepley wrote:
> On Sat, Apr 21, 2012 at 6:31 PM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi,
>     May I know if ex22f is complete? I can't find :
>     call KSPGetSolution(ksp,x,ierr)
>     If I entered it, it says x not found.
> This is correct in petsc-dev. What version are you using?
>   Thanks,
>     Matt
>     Thank you!
>     Yours sincerely,
>     TAY wee-beng
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120422/433fdb62/attachment.htm>
