[petsc-users] SNES and ghosted vector of unknowns
    Matthew Knepley
    knepley at gmail.com
    Fri Apr 20 09:08:27 CDT 2012
On Fri, Apr 20, 2012 at 9:53 AM, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> I am using SNES to solve a simple nonlinear system.
> My vector of unknowns (x) is ghosted, and before (i.e. with my own
> home brewed nonlinear solver) I had to always update the ghosted
> values after a linear solve with ksp. How can I now force the update,
> if I am not calling ksp myself?
You can use
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/SNES/SNESSetUpdate.html
Also, you could investigate using DM, where this should be automatic, but
that is probably
a bigger change to your code.
   Matt
> Thanks for any hints,
> Dominik
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120420/6b441931/attachment.htm>
