[petsc-users] ksp_monitor_true_residual_norm
Randall Mackie
rlmackie862 at gmail.com
Thu Apr 19 12:12:18 CDT 2012
Hi Matt and Barry,
I tried this again, but this time I used a c subroutine like Barry
suggested, which is this:
#include "petsc.h"
PetscErrorCode shellkspmonitor_(KSP ksp,PetscInt n,PetscReal rnorm,void
*dummy)
PetscErrorCode ierr=0;
if (n % 10) {
ierr = KSPMonitorTrueResidualNorm(ksp,n,rnorm,dummy);CHKERRQ(ierr);
return ierr;
In my Fortran code, I declared shellkspmonitor as external, then I called
KSPSetMonitor as follows:
call KSPMonitorSet(ksp,shellkspmonitor,PETSC_NULL_OBJECT,
PETSC_NULL_FUNCTION, ierr)
But I am still getting the same error as before:
[0]PETSC ERROR: [1]PETSC ERROR: [2]PETSC ERROR: [3]PETSC ERROR:
--------------------- Error Message ------------------------------------
[3]PETSC ERROR: [2]PETSC ERROR: Invalid argument!
Invalid argument!
[3]PETSC ERROR: Wrong type of object: Parameter # 1!
[3]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29 13:45:54
CDT 2011
[3]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Invalid argument!
[0]PETSC ERROR: Wrong type of object: Parameter # 1!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29 13:45:54
CDT 2011
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: PetscViewerASCIIAddTab() line 277 in
src/sys/viewer/impls/ascii/filev.c
[0]PETSC ERROR: KSPMonitorTrueResidualNorm() line 233 in
src/ksp/ksp/interface/iterativ.c
[0]PETSC ERROR: shellkspmonitor_() line 7 in custom_monitor.c
[3]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[3]PETSC ERROR: See docs/index.html for manual pages.
So, there is either a problem in one of the PETSc routines, or the call
from Fortran to KSPMonitorSet
is wrong, although I have copied the calling sequence from the example in
/src/ksp/ksp/examples/tutorials/ex2f.F
In fact, you can reproduce this error using ex2f.F, simply swapping in the
custom monitor above for
the MyKSPMonitor of that example. I can send you the modified code and c
subroutine to test if you want.
Thanks, Randy
On Tue, Apr 17, 2012 at 10:39 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Apr 17, 2012 at 1:27 PM, Randall Mackie <rlmackie862 at gmail.com>wrote:
>> Hi Barry,
>> I've tried implementing this in Fortran, following ex2f.F in
>> /src/ksp/ksp/examples/tutorials, but
>> it is bombing out with the following message:
>> ---------------------- Error Message ------------------------------------
>> [0]PETSC ERROR:
>> CDT 2011
>> [0]PETSC ERROR:
>> CDT 2011
>> [1]PETSC ERROR: PetscViewerASCIIAddTab() line 277 in
>> [1]PETSC ERROR: KSPMonitorTrueResidualNorm() line 233 in
>> [1]PETSC ERROR: ourmonitor() line 103 in
>> src/ksp/ksp/interface/ftn-custom/zitfuncf.c
>> [1]PETSC ERROR: KSPMonitor() line 1429 in src/ksp/ksp/interface/itfunc.c
>> [1]PETSC ERROR: KSPSolve_CG() line 255 in src/ksp/ksp/impls/cg/cg.c
>> [1]PETSC ERROR: KSPSolve() line 423 in src/ksp/ksp/interface/itfunc.c
>> I am running PETSC 3.2-p5.
>> I have set my monitor routine as follows:
>> subroutine ShellKSPMonitor(ksp, n, rnorm, dummy, ierr)
>> implicit none
>> #include "finclude/petsc.h"
>> KSP :: ksp
>> PetscErrorCode :: ierr
>> PetscInt :: n, dummy
>> PetscReal :: rnorm
>> if (n == 200) then
>> call KSPMonitorTrueResidualNorm(ksp,n,rnorm,dummy,ierr)
> I think it should work if dummy is 0, but we should really do NULL
> conversion
> here and you should pass PETSC_NULL.
> Matt
>> end if
>> return
>> end subroutine ShellKSPMonitor
>> And then in the main program I call:
>> call KSPMonitorSet(ksp,ShellKSPMonitor,PETSC_NULL_OBJECT,
>> As I have followed the example in the PETSc documentation, I am unsure
>> where I have made a mistake.
>> Thanks,
>> Randy M
>> On Fri, Apr 13, 2012 at 5:01 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> Write a one line monitor that calls the true residual monitor when
>>> desired:
>>> PetscErrorCode myKSPMonitorTrueResidualNorm(KSP ksp,PetscInt
>>> n,PetscReal rnorm,void *dummy)
>>> if (n % 10) {
>>> ierr =
>>> then call this on the KPS
>>> ierr =
>>> KSPMonitorSet(ksp,myKSPMonitorTrueResidualNorm,PETSC_VIEWER_STDOUT,0);CHKERRQ(ierr);
>>> On Apr 13, 2012, at 6:52 PM, Randall Mackie wrote:
>>> > In using ksp_monitor_true_residual_norm, is it possible to change how
>>> often this information is printed out?
>>> > That is, instead of every iteration, say I only want to see it every
>>> 10 or 20 iterations. Is there an easy way
>>> > to do this, other than creating my own monitor and doing it myself?
>>> > Thanks, Randy M.
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120419/7698cd47/attachment.htm>
