[petsc-users] How to include PETSc in an Eclipse CDT project
Christian Staudt christian.staudt at ira.uka.de
Wed Apr 18 11:40:30 CDT 2012
Hello PETSc users,
I am new to PETSc (and, coming from the Java world, not an experienced C++ developer). I hope my question is appropriate on this list.
Here's my problem: I'd like to build an application in C++ against PETSc, using Eclipse CDT. However, I have problems including PETSc as a library in my Eclipse CDT project.
I have tried the following for my test project:
In Properties>>C/C++ Build>>Settings>>GCC C++ Compiler >> Includes I add the path
/usr/local/petsc/include/
In Properties>>C/C++ Build>>Settings>>MacOS X C++ Linker >> Libraries, I add
/usr/local/petsc/arch-darwin-c-debug/lib/libpetsc.a
to "Libraries (-l)" and
to "Library search path (-L)"
Now I try to build a simple Hello World program which has the lines
#include <petsc.h>
#include <petscmat.h>
at the beginning of the main file.
I get compiler errors for almost every line of the PETSc header files, indicating that basic types are not found, for example:
/usr/local/petsc/include/petscmat.h:1643: error: 'PetscScalar' has not been declared
/usr/local/petsc/include/petscmat.h:1721: error: 'PetscReal' has not been declared
/usr/local/petsc/include/petscmat.h:1152: error: 'PetscReal' does not name a type
Can anyone tell me what might be the problem? Thank you.
Chris
