[petsc-users] PETSc Gather
TAY wee-beng
zonexo at gmail.com
Tue Apr 17 06:07:38 CDT 2012
I'm not sure if this is a naive question, but is there any speed or
performance difference when using VecScatterCreateToZero or similar
routine, compared to MPI standard routines such as mpi_gather,
mpi_gatherv etc?
Yours sincerely,
TAY wee-beng
On 16/4/2012 6:26 PM, Jed Brown wrote:
> On Mon, Apr 16, 2012 at 11:25, Abraham Taicher
> <ataicher at ices.utexas.edu <mailto:ataicher at ices.utexas.edu>> wrote:
> Hi,
> I have a parallel vector spread across all processors that I would
> like to gather into a single processor, say the root processor.
> Is there PETSc functionality to do this? I tried looking for a
> PETSc gather function but the one I found, VecStrideGather
> <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecStrideGather.html>,
> does not seem to apply. Should I simply use the MPI routine
> MPI_Gather?
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecScatterCreateToZero.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120417/7fad7999/attachment.htm>
