[petsc-users] determining dof at runtime
Juha Jäykkä juhaj at iki.fi
Mon Apr 16 16:11:12 CDT 2012
Hi list!
I am trying to create a 3D DA such that I can use DMDAVecGetArray() and access
it using array indexing. I know how to get several dof in the DA and how using
a struct to access the members works, when the dof is determined at compile-
time (so accesses like array[1][2][3].member1[2] are computed correctly.
However, I would like to determine dof at run-time. Creating a struct with
pointers (even of the type member[]) of course gives me a struct whose size
depends on the *pointer* size, not my dof. So I was wondering if I could work
around this somehow, but do not seem to be able to.
My DA is created by
DMDACreate3d(PETSC_COMM_WORLD,
             DMDA_BOUNDARY_GHOSTED, DMDA_BOUNDARY_GHOSTED,
             DMDA_BOUNDARY_GHOSTED, DMDA_STENCIL_BOX,
             2, 2, 2,
             PETSC_DECIDE, PETSC_DECIDE, PETSC_DECIDE,
             ndof, NGHOSTS,
             PETSC_NULL, PETSC_NULL, PETSC_NULL,
             &da);
so my Vec does have the correct dof, but I cannot seem to fool C to address
this as array[z][y][x][n] or something of the like, where the last index is
the index to ndof. (Usually I would index that as array[z][y][x].member[n],
but now I do not know how to make that happen since I cannot define a struct
whose storage size is not known to the compiler.)
Any ideas? Or am I trying to accomplish something which is not possible? (If
so, why would that be? The vector is of the correct size.)
Cheers,
-Juha
		| Juha Jäykkä, juhaj at iki.fi			|
Name: not available
Desc: This is a digitally signed message part.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120416/4b62ebe5/attachment.pgp>
