[petsc-users] Petsc CMake conf
Mohammad Mirzadeh
mirzadeh at gmail.com
Fri Apr 13 18:03:32 CDT 2012
Sure. Will let you know if I found something.
Once again thanks. One of the best things about PETSc is the community --
You don't see this often in other packages :)
On Fri, Apr 13, 2012 at 4:01 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Apr 13, 2012 at 17:57, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>> my code -- I'm experimenting with CMake to manage my project and link it
>> to petsc. right now, it seems to link to petsc correctly and I can run the
>> code just fine. It just produces those messages when generating the
>> makefile.
> Feel free to investigate why it was failing and let me know or send a
> patch. It shouldn't be hard to figure out from the logs.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120413/beb92454/attachment.htm>
