[petsc-users] Petsc CMake conf
Mohammad Mirzadeh mirzadeh at gmail.com
Fri Apr 13 17:57:33 CDT 2012
On Fri, Apr 13, 2012 at 3:49 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Apr 13, 2012 at 17:47, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>> ust a question though. When I run cmake in the build directory I get:
>> -- Performing Test MULTIPASS_TEST_1_petsc_works_minimal
>> -- Performing Test MULTIPASS_TEST_1_petsc_works_minimal - Failed
>> -- Performing Test MULTIPASS_TEST_2_petsc_works_allincludes
>> -- Performing Test MULTIPASS_TEST_2_petsc_works_allincludes - Failed
>> -- Performing Test MULTIPASS_TEST_3_petsc_works_alllibraries
>> -- Performing Test MULTIPASS_TEST_3_petsc_works_alllibraries - Failed
>> -- Performing Test MULTIPASS_TEST_4_petsc_works_all
>> -- Performing Test MULTIPASS_TEST_4_petsc_works_all - Failed
>> -- PETSc could not be used, maybe the install is broken.
>> -- PETSc could not be found.  Be sure to set PETSC_DIR and PETSC_ARCH.
>>  (missing:  PETSC_EXECUTABLE_RUNS)
>> But actually I can make and run the binary without any problem! should I
>> ignore this? I do set PETSC_DIR and PETSC_ARCH in my CMakeLists.txt.
> Which binary runs? Check the CMake error files and use cmake --trace or
> --debug-output.
my code -- I'm experimenting with CMake to manage my project and link it to
petsc. right now, it seems to link to petsc correctly and I can run the
code just fine. It just produces those messages when generating the
makefile.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120413/0b41ce9b/attachment-0001.htm>
