[petsc-users] Strange error(?) message
Mohammad Mirzadeh
mirzadeh at gmail.com
Mon Apr 9 22:19:13 CDT 2012
-on_error_attach_debugger does not start the debugger. I traced it upto the
following call: MatPartitioningApply(). It runs fine up until that
function call and then gives the error.
Also, to make things even look more weird, I got the following once I was
running it:
Key 10176 not found!
INTERNAL ERROR: Invalid error class (66) encountered while returning from
PMPI_Waitall. Please file a bug report.
Do you happen to know what that could mean? The funny thing is, it only
happened once!
On Mon, Apr 9, 2012 at 7:57 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Mon, Apr 9, 2012 at 21:56, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>> :( that's all I see. Do you mean running with -on_error_attach_debugger?
> Sure, or directly in a debugger. Does execution make it to main? Something
> is either not catching errors or is improperly calling exit() or similar.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120409/1d6d0f61/attachment.htm>
