[petsc-users] Strange error(?) message
Mohammad Mirzadeh
mirzadeh at gmail.com
Mon Apr 9 21:56:07 CDT 2012
:( that's all I see. Do you mean running with -on_error_attach_debugger?
On Mon, Apr 9, 2012 at 7:29 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Always send the whole error message. If this is all you see, then
> something is misbehaving and you'll have to catch the message in a debugger.
> On Mon, Apr 9, 2012 at 20:10, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>> Hi,
>> I have this strange behavior that sometimes when I run the code on
>> certain number of processors and for a certain problem size, I get a
>> message like:
>> "key # not found!"
>> where # is just some number (like 9087 but changes every time I run it).
>> Is there something wrong with my MPI? is this even an MPI message or
>> something else? Sorry my question is this broad, but I have no clue where
>> this message is popping from! PETSc does not produce any error message when
>> this happens and the code is valgrind clean.
>> I'd appreciate any input.
>> Thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120409/29abaee5/attachment.htm>
