[petsc-users] Problem with "likely location of problem given in stack below"?
Alan Wei zhenglun.wei at gmail.com
Sat Apr 7 17:18:10 CDT 2012
Thanks Dr. Brown,
    It works. I made a wrong comment command so that the code did not go
through the compilation. So it gives the same error message since I ran the
old version of execution file.
    BTW, this ex29.c is a solver for 2D poisson equation. I wonder if there
is any 3D Poisson Equation solver in PETSc code?
thanks,
Alan
On Sat, Apr 7, 2012 at 5:12 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sat, Apr 7, 2012 at 17:10, Alan Wei <zhenglun.wei at gmail.com> wrote:
>> A little problem comes up. I commented out VTK part, the code still has
>> the same error message popping up.
> Well it can't be the same error message if that code isn't being executed.
> Send the whole error message.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120407/7117d423/attachment.htm>
