[petsc-users] Coarsening vectors
Fri Apr 6 17:59:07 CDT 2012
On Fri, Apr 6, 2012 at 17:56, Mohamad M. Nasr-Azadani <mmnasr at gmail.com>wrote:
> I just noticed the command DMCoarsen().
> I was wondering if there is a simple command which copies the values of
> the (global) vector created via the fine DM into the coarse DM?
with petsc-dev or petsc-3.2 respectively,
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/DM/DMCreateInterpolation.html
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMGetInterpolation.html
then
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatRestrict.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120406/cd8f846b/attachment.htm>
