[petsc-users] question about MatMatMultTranspose
Gao Bin
bin.gao at uit.no
Thu Apr 5 07:42:08 CDT 2012
Hi Jed,
Good to know it is simpler ;-) I am switching to the developed version and try it. Again, thank you very much.
P.S., Moreover, I notice that some functions is not for MATMPIDENSE. May I ask if they are too difficult to implement (for instance, C=A*B^T and C=A^T*B for MATMPIDENSE)? Thank you.
Cheers
Gao
From: petsc-users-bounces at mcs.anl.gov [petsc-users-bounces at mcs.anl.gov] on behalf of Jed Brown [jedbrown at mcs.anl.gov]
Sent: Thursday, April 05, 2012 2:32 PM
To: PETSc users list; Hong Zhang
Subject: Re: [petsc-users] question about MatMatMultTranspose
On Thu, Apr 5, 2012 at 05:16, Gao Bin <bin.gao at uit.no<mailto:bin.gao at uit.no>> wrote:
Thank you for your quick reply. But as pointed out at http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatMatTransposeMult.html:
This routine is currently only implemented for pairs of SeqAIJ matrices. C will be of type MATSEQAIJ.
Therefore I can not use it for dense matrix, am I right? If so, will MatMatTransposeMult be extended for other types of matrix later on? Thank you very much.
This is much simpler than the sparse case. Hong, did you intend to get around to this?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120405/e56a946b/attachment.htm>
