[petsc-users] question about MatMatMultTranspose
Gao Bin bin.gao at uit.no
Thu Apr 5 07:16:40 CDT 2012
Hi Jed,
Thank you for your quick reply. But as pointed out at http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatMatTransposeMult.html:
This routine is currently only implemented for pairs of SeqAIJ matrices. C will be of type MATSEQAIJ.
Therefore I can not use it for dense matrix, am I right? If so, will MatMatTransposeMult be extended for other types of matrix later on? Thank you very much.
Cheers
Gao
From: petsc-users-bounces at mcs.anl.gov [petsc-users-bounces at mcs.anl.gov] on behalf of Jed Brown [jedbrown at mcs.anl.gov]
Sent: Thursday, April 05, 2012 2:09 PM
To: PETSc users list
Subject: Re: [petsc-users] question about MatMatMultTranspose
On Thu, Apr 5, 2012 at 04:43, Gao Bin <bin.gao at uit.no<mailto:bin.gao at uit.no>> wrote:
I would like to use PETSc perform matrix-matrix multiplication C=A*B^T. I notice that MatMatMultTranspose could calculate C=A^T*B, but which is not I want.
Does anyone know how to perform C=A*B^T using PETSc (I know I could first calculate B^T and call MatMatMult with A and B^T, but it might not be efficient, is it?)? Thank you in advance.
Use petsc-dev. That routine is renamed (http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatTransposeMatMult.html) and the one you want is
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120405/e2c9a14d/attachment.htm>
