[petsc-users] Most efficient way to transfer a vector to a single processor
Wed Apr 4 16:51:15 CDT 2012
On Wed, Apr 4, 2012 at 4:47 PM, Andrew Spott <andrew.spott at gmail.com> wrote:
> I'm interested in moving a vector to a single processor (so I can output
> it in some custom way), but I can't find a simple way to do that.
> Is the easiest way to output the parallel vector to a file and then read
> it in to a single processor vector?
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Vec/VecScatterCreateToZero.html
> Also, an unrelated question:  If I have a vector that I'm using as the
> result of a matrix vector product, but it is initially empty, do I need to
> initialize it in any way?  or can I just create it and run with it:
> … create x and A ...
> VecCreate(world, &b);
This create is wrong, that Vec will be overwritten.
> MatGetVecs(A,&x,&b);
You can jsut use these vectors.
   Matt
> … do stuff with x and A ...
> MatMult(A,x,b);
> Thanks for the help,
> -Andrew
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120404/8ea1870b/attachment.htm>
