[petsc-users] Questions about PCMG
Yuqi Wu ywu at culink.Colorado.EDU
Wed Apr 4 13:34:52 CDT 2012
Thanks, Adam.
Yes. I am using the Galerkin coarse grids. But I am not sure whether the coarse grid is not getting refactored in the second SNES solve or the fine grid smoother is not getting refactored in the second SNES solve.
In the -info output attached in the previous email, the fine grid matrix is of size 11585 by 11585, and the coarse grid matrix is of size 4186 by 4186. In the -info output, I found out three MatLUFactorSymbolic_SeqAIJ routines, one for fine martrix, and two for coarse matrix.
[0] MatLUFactorSymbolic_SeqAIJ(): Reallocs 2 Fill ratio:given 5 needed 11.401
[0] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 11.401 or use
[0] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,11.401);
[0] MatLUFactorSymbolic_SeqAIJ(): for best performance.
[0] Mat_CheckInode_FactorLU(): Found 8057 nodes of 11585. Limit used: 5. Using Inode routines
[0] MatLUFactorSymbolic_SeqAIJ(): Reallocs 1 Fill ratio:given 5 needed 7.07175
[0] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 7.07175 or use
[0] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,7.07175);
[0] Mat_CheckInode_FactorLU(): Found 1764 nodes of 4186. Limit used: 5. Using Inode routines
So I believe that the fine grid smoother is not getting refactored in the second SNES solve.
Best
Yuqi
---- Original message ----
>Date: Wed, 4 Apr 2012 14:24:28 -0400
>From: petsc-users-bounces at mcs.anl.gov (on behalf of "Mark F. Adams" <mark.adams at columbia.edu>)
>Subject: Re: [petsc-users] Questions about PCMG
>To: PETSc users list <petsc-users at mcs.anl.gov>
>I would expect 4 calls to MatLUFactorSym here.  It looks like the coarse grid is not getting refactored in the second SNES solve.
>Are you using Galerkin coarse grids?  Perhaps you are not setting a new coarse grid with KSPSetOperator and so MG does not bother refactoring it.
>Mark
>On Apr 4, 2012, at 1:53 PM, Yuqi Wu wrote:
>> Thank you.
>> Can I ask another question?
>> In my log summary output, it shows that although there are two SNES iteration and total 9 linear iterations. The functions MatLUFactorSym and MatLUFactorNum are only called for three times.
>> MatLUFactorSym         3 1.0 1.4073e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.5e+01  1  0  0  0  2   1  0  0  0  2     0
>> MatLUFactorNum         3 1.0 3.2754e+01 1.0 9.16e+09 1.0 0.0e+00 0.0e+00 0.0e+00 31 97  0  0  0  32 97  0  0  0   280
>> I checked the -info output. It shows that One MatLUFactorSymbolic_SeqAIJ() is called in down smoother of the first SNES, one MatLUFactorSymbolic_SeqAIJ() is called in the coarse solve of the first SNES, and one MatLUFactorSymbolic_SeqAIJ() is called in the down smoother of the second SNES.
>> Do you have any ideas why there are 9 multigrid iterations, but only 3 MatLUFactorSymbolic calls in the program?
>> Best
>> Yuqi
>>> Date: Tue, 3 Apr 2012 20:08:27 -0500
>>> From: petsc-users-bounces at mcs.anl.gov (on behalf of Barry Smith <bsmith at mcs.anl.gov>)
>>>  There are two linear solves (for 1 SNES and 2 SNES) so there are two MGSetUp on each level. Then a total of 9 multigrid iterations (in both linear solves together) hence 9 smoother on level 0 (level 0 means coarse grid solve). One smooth down and one smooth up on level 1 hence 18 total smooths on level 1.  9 computation of residual on level 1 and 18 MgInterp because that logs both the restriction to level 0 and the interpolation back to level 1 and 18 = 9 + 9.
>>>  Barry
>>> On Apr 3, 2012, at 7:57 PM, Yuqi Wu wrote:
>>>> Hi, Barry,
>>>> Thank you. If my program converges in two SNES iteration,
>>>> 0 SNES norm 1.014991e+02, 0 KSP its (nan coarse its average), last norm 0.000000e+00
>>>> 1 SNES norm 9.925218e-05, 4 KSP its (5.25 coarse its average), last norm 2.268574e-06.
>>>> 2 SNES norm 1.397282e-09, 5 KSP its (5.20 coarse its average), last norm 1.312605e-12.
>>>> And -pc_mg_log shows the following output
>>>> MGSetup Level 0        2 1.0 3.4091e-01 2.1 0.00e+00 0.0 3.0e+02 6.0e+04 3.0e+01  1  0  3 11  2   1  0  3 11  2     0
>>>> MGSmooth Level 0       9 1.0 1.2126e+01 1.0 9.38e+08 3.2 2.8e+03 1.7e+03 6.4e+02 33 71 28  3 34  35 71 28  3 35   415
>>>> MGSetup Level 1        2 1.0 1.3925e-01 2.1 0.00e+00 0.0 1.5e+02 3.1e+04 2.3e+01  0  0  1  3  1   0  0  1  3  1     0
>>>> MGSmooth Level 1      18 1.0 5.8493e+00 1.0 3.66e+08 3.1 1.5e+03 2.9e+03 3.6e+02 16 28 15  3 19  17 28 15  3 19   339
>>>> MGResid Level 1        9 1.0 1.1826e-01 1.4 1.49e+06 2.4 2.0e+02 2.7e+03 9.0e+00  0  0  2  0  0   0  0  2  0  0    70
>>>> MGInterp Level 1      18 1.0 1.2317e-01 1.3 7.74e+05 2.2 3.8e+02 1.1e+03 1.8e+01  0  0  4  0  1   0  0  4  0  1    37
>>>> What are the MGSmooth, MGResid, MGInterp represent for?
>>>> Best
>>>> Yuqi
>>>>> Date: Tue, 3 Apr 2012 19:19:23 -0500
>>>>> -pc_mg_log doesn't have anything to do with DA or DMMG it is part of the basic PCMG. Are you sure you are calling SNESSetFromOptions()?
>>>>> Barry
>>>>> On Apr 3, 2012, at 6:56 PM, Yuqi Wu wrote:
>>>>>> Hi, Mark,
>>>>>> Thank you so much for your suggestion.
>>>>>> The problem 1 is resolved by avoiding calling PCMGSetNumberSmoothUp.
>>>>>> But since I am using the unstructured grid in my application, I didn't use DA or dmmg, so -pc_mg_log didn't give any level information. I try to run my code using -info with 1 processor, and I find out some interesting issues.
