[petsc-users] transfer vector data diagonally on DA
khalid ashraf khalid_eee at yahoo.com
Mon Apr 2 16:53:08 CDT 2012
Thanks Matt. It works now.
I have another problem. I am writing this program.
 for (k=zs; k<zs+zm; k++) {
  for (j=ys; j<ys+ym; j++) {
  for (i=xs; i<xs+xm; i++) {
 if ( i!=(mx-1) || j!=my-1 || k!=mz-1)
bodyFx[0]=1;
bodyFx[1]=-0.3;
bodyFx[2]=-0.3;
bodyFx[3]=-0.3;
row[0]=k*mx*my+j*mx+i;
row[1]=k*mx*my+j*mx+i+1;
row[2]=k*mx*my+(j+1)*mx+i;
row[3]=(k+1)*mx*my+j*mx+i;
VecSetValues(fx_test,4,row,bodyFx,ADD_VALUES);
VecAssemblyBegin(fx_test);
VecAssemblyEnd(fx_test);
Output: Print fx_test
 Here fx_test is a global vector. This program gives correct output on 1 proc. but on 4 processors,
the program runs but the outputs are wrong.
I also tried
bodyFx[0]=1;
bodyFx[1]=-0.3;
bodyFx[2]=-0.3;
bodyFx[3]=-0.3;
 fx1_localptr[k][j][i+1]+=bodyFx[4];
 fx1_localptr[k][j+1][i]+=bodyFx[3];
 fx1_localptr[k+1][j][i]+=bodyFx[1];
 fx1_localptr[k][j][i]+=bodyFx[0];
Here, fx1_localptr is an array from a local vector that is communicated from the global vector fx_test.
In this case as well, I get similar errors.
Thanks.
Khalid
Some final numbers of the vector with 8*8*6 grid, 4 proc,
-2.9999999999999999e-01
1.0000000000000009e-01
0.0000000000000000e+00
4.0000000000000002e-01
Some final numbers of the vector with 8*8*6 grid, 1 proc,
To: khalid ashraf <khalid_eee at yahoo.com>; PETSc users list <petsc-users at mcs.anl.gov>
Sent: Monday, April 2, 2012 5:41 AM
Subject: Re: [petsc-users] transfer vector data diagonally on DA
On Mon, Apr 2, 2012 at 3:36 AM, khalid ashraf <khalid_eee at yahoo.com> wrote:
Hi Jed,
>I am using petsc/3.1 and the include file "petscdmda.h" is not working. I am using the "petscda.h"
>and DACreate3D.
>unew_localptr[][][] is from a global vector using VecGetArray
>u_localptr[][][] is from a local vector communicated from a global vector.
>I tried
>unew_localptr[k][j][i]=u_localptr[k-1][j-1][i-1]
>but it gives Segmentation Violation error.
I would guess (because you provide almost no information about what you are doing), that
this is a domain on the edge. If you truly mean to have a periodic domain, you must set that in the
creation call. Then the local vector will also ghost regions outside the domain boundary.
   Matt
I also tried unew_localptr[k][j][i]=u_localptr[k][j+1][i+1] which works but
>unew_localptr[k][j][i]=u_localptr[k+1][j+1][i+1] or unew_localptr[k][j][i]=u_localptr[k][j-1][i-1]
>does not work. I am running the program on4 processors.
>Thanks.
>  ierr = DACreate3d(PETSC_COMM_WORLD,DA_YPERIODIC,DA_STENCIL_BOX,appctx.l,appctx.m,appctx.n,
>                    PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE,1,1,PETSC_NULL,PETSC_NULL,PETSC_NULL,
>                    &appctx.da);CHKERRQ(ierr);
>  if(i!=0 || j!=0 || k!=0|| i!=mx-1 || j!=my-1 || k!=mz-1)
>  unew_localptr[k][j][i]=u_localptr[k+1][j+1][i+1];
>________________________________
>From: Jed Brown <jedbrown at mcs.anl.gov>
>Sent: Sunday, April 1, 2012 10:07 PM
>On Sun, Apr 1, 2012 at 22:01, khalid ashraf <khalid_eee at yahoo.com> wrote:
>I want to transfer vector data diagonally in the DA grid like
>>if(i!=mx-1 || j!=my-1 || k!=mz-1){
>>u_new[k+1][j+1][i+1]=u[k][j][i];}
>>Could you please suggest the best way to do it minimizing interprocessor assignments.
>Both are on the same DMDA?
>Communicate U to Ulocal (DMGlobalToLocalBegin/End) using a BOX stencil with width at least 1, get the global array u_new[][][] from UGlobalNew and the local arrays u[][][] from Ulocal, then assign u_new[k][j][i] = u[k-1][j-1][i-1].
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120402/198a0763/attachment.htm>
