[petsc-users] code hangs inside SUPERLU DIST
Wen Jiang
jiangwen84 at gmail.com
Sun Apr 1 14:12:43 CDT 2012
Hello Everyone,
I am using KSPPRECONLY type ksp with SUPERLU DIST. However, I found my code
hangs inside superlu_dist solver and never finishes.
The problem I am solving is a time-dependent nonlinear pde and I use fully
Newton-Raphson for each time step. So my code will look like,
For Time STEP = start to end
For Newton-Raphson Iterations = 1 to max iterations
Calculate Matrix A;
END Newton-Raphson Iterations
End Time STEP
Could you give me any hints what the problem might be? I am using Petsc 3.1
p8 and superlu dist v2.4.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120401/daf74ebd/attachment.htm>
