[petsc-users] Question about ksp ex3.c
Matija Kecman
matijakecman at gmail.com
Thu Sep 29 06:28:58 CDT 2011
Thanks for your response Jed! I've been doing some other
investigations using this example. I made some small modifications:
1. Added preallocation as Jed Brown suggested in a previous email
(http://lists.mcs.anl.gov/pipermail/petsc-users/2011-June/009054.html).
2. Added a small VTK viewer.
3. Set the initial guess to zero.
4. Changed the entries in the element stiffness matrix to the following:
Ke[ 0] = 2./3.; Ke[ 1] = -1./6.; Ke[ 2] = -1./3.; Ke[ 3] = -1./6.;
Ke[ 4] = -1./6.; Ke[ 5] = 2./3.; Ke[ 6] = -1./6.; Ke[ 7] = -1./3.;
Ke[ 8] = -1./3.; Ke[ 9] = -1./6.; Ke[10] = 2./3.; Ke[11] = -1./6.;
Ke[12] = -1./6.; Ke[13] = -1./3.; Ke[14] = -1./6.; Ke[15] = 2./3.;
I computed these by evaluating $K^e_{ij} = \int_{\Omega_e} \nabla
\psi^e_i \cdot \nabla \psi^e_j \, \mathrm{d}\Omega$ with the shape
functions $\psi^e$ corresponding to a bilinear quadratic finite
element denoted by $\Omega_e$. This is different to what was
originally in the code and I'm not sure where the original code comes
from. This isn't important so you can just ignore it if you like, I
get the same solution using both matrices.
I am running on a two compute node clusters which each look as
follows: 2 quad-core Intel Xeon 5345 processors, 16GB memory. The node
clusters are connected with the following interconnect: Mellanox
InfiniScale 2400. I computed my results using a machine file which
specifies that (up to) the first 8 processes are computed on node1 and
the second group of 8 processes are computed on node2. My timing
results are shown in the table below, I'm running each test using
Bi-CGStab with no preconditioning (-ksp_type bcgs -pc_type none) on a
computational grid of 800 x 800 cells, so 641601 DOFs. I have attached
my modified source code (you could look at my changes using diff) and
the -log_summary output for each of the tests.
# number of processes | time for KSPsolve() | iterations to
convergence | norm of error
1 64.008 692 0.00433961
2 36.2767 626 0.00611835
4 35.9989 760 0.00311053
8 30.5215 664 0.00599148
16 14.1164 710 0.00792162
Why is the scaling so poor? I have read the FAQ
(http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#computers),
am I experiencing the problem described? I think my machine has a
bandwidth of 2GB/s per process as suggested. Also, how can you tell if
a computation is memory bound by looking at the -log_summary?
Many thanks,
Matija
On Tue, Sep 20, 2011 at 11:44 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Sep 20, 2011 at 11:45, Matija Kecman <matijakecman at gmail.com> wrote:
>> $ mpirun -np 1 ./ex3 -ksp_type gmres -pc_type none -m 100
>> Norm of error 0.570146 Iterations 0
> This uses a nonzero initial guess so the initial residual norm is compared to the right hand side.
> $ ./ex3 -ksp_type gmres -ksp_monitor -m 100 -pc_type none -ksp_converged_reason -info |grep Converged
> [0] KSPDefaultConverged(): user has provided nonzero initial guess, computing 2-norm of preconditioned RHS
> [0] KSPDefaultConverged(): Linear solver has converged. Residual norm 1.113646413065e-04 is less than relative tolerance 1.000000000000e-05 times initial right hand side norm 1.291007358616e+01 at iteration 0
> You can use the true residual, it just costs something so it's not enabled by default:
> $ ./ex3 -ksp_type gmres -ksp_monitor -m 100 -pc_type none -ksp_converged_reason -ksp_converged_use_initial_residual_norm
> [many iterations]
> Linear solve converged due to CONVERGED_RTOL iterations 1393
> Norm of error 0.000664957 Iterations 1393
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110929/1c07af45/attachment-0005.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110929/1c07af45/attachment-0006.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110929/1c07af45/attachment-0007.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110929/1c07af45/attachment-0008.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110929/1c07af45/attachment-0009.obj>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110929/1c07af45/attachment-0001.c>
