[petsc-users] [petsc-3.2] LSQR new convergence test
Alexander Grayver agrayver at gfz-potsdam.de
Thu Sep 22 08:56:52 CDT 2011
Thank you guys,
It runs well now.
Finally, my program works with petsc-3.2, at least under linux.
Alexander
On 22.09.2011 14:54, Satish Balay wrote:
> Loks like Barry sent you the wrong file. zitfuncf90.c belongs to
> src/ksp/ksp/interface/f90-custom [and is unchanged]
> Try the attached patch
> cd petsc-3.2-p2
> patch -Np1<  ksp-conv.patch
> Satish
> On Thu, 22 Sep 2011, Alexander Grayver wrote:
>> Barry,
>> Unfortunately, the problem is still there. Even though I put zitfuncf90.c into
>> src/ksp/ksp/interface/ftn-custom, modified makefile there and made
>> configure/make from scratch.
>> When are you going to release new patch?
>> Regards,
>> Alexander
>> On 21.09.2011 21:58, Barry Smith wrote:
>>>      Alexander,
>>>       Yes, a problem with trying to handle C pointers on the Fortran side. It
>>> will be fixed in the next patch release. You can drop the attached file into
>>> src/ksp/ksp/interface/ftn-custom run make in that directory and then relink
>>> your program and it should work.
>>>       Barry
>>> [see attached file: zitfuncf90.c]
>>> On Sep 21, 2011, at 11:00 AM, Alexander Grayver wrote:
>>>> Barry,
>>>> I think the error is related to this
>>>> PetscFortranAddr cctx
>>>> definition. Speaking in terms of C++ notation, it seems that PETSc
>>>> takes&cctx as KSPDefaultConvergedCtx, however real KSPDefaultConvergedCtx
>>>> is *cctx.
>>>> Not sure if I'm clear now, but it's easy to see if you trace code like
>>>> that:
>>>>    KSP  ksp
>>>>    call KSPCreate(MPI_COMM_WORLD,ksp,ierr)
>>>>    call KSPSetType(ksp,KSPLSQR,ierr)
>>>>    call KSPDefaultConvergedCreate(cctx,ierr)
>>>>    call
>>>> KSPSetConvergenceTest(ksp,KSPDefaultConverged,cctx,PETSC_NULL_FUNCTION,ierr)
>>>>    call KSPDestroy(ksp,ierr)
>>>> I guess the error should be reproducible from the code above.
>>>> Regards,
>>>> Alexander
>>>> On 21.09.2011 17:17, Alexander Grayver wrote:
>>>>> Thanks Barry, I added your code and solver works well now, but when I
>>>>> call KSPDestroy afterward it crashes:
>>>>> [8]PETSC ERROR: --------------------- Error Message
>>>>> [8]PETSC ERROR: Invalid argument!
>>>>> [8]PETSC ERROR: Wrong type of object: Parameter # 1!
>>>>> [8]PETSC ERROR:
>>>>> [8]PETSC ERROR: Petsc Release Version 3.2.0, Patch 2, Fri Sep 16
>>>>> 10:10:45 CDT 2011
>>>>> [8]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>> [8]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>> [8]PETSC ERROR: See docs/index.html for manual pages.
>>>>> [8]PETSC ERROR:
>>>>> [8]PETSC ERROR: /home/test on a openmpi-i named node226 by user Wed Sep
>>>>> 21 17:01:23 2011
>>>>> [8]PETSC ERROR: Libraries linked from
>>>>> /home/lib/petsc-3.2-p2/openmpi-intel-complex-debug-f/lib
>>>>> [8]PETSC ERROR: Configure run at Tue Sep 20 09:28:29 2011
>>>>> [8]PETSC ERROR: Configure options
>>>>> --with-petsc-arch=openmpi-intel-complex-debug-f
>>>>> --with-fortran-interfaces=1 --with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2
>>>>> --with-scalar-type=complex
>>>>> --with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t
>>>>> --with-precision=double --with-x=0
>>>>> [8]PETSC ERROR:
>>>>> [8]PETSC ERROR: VecDestroy() line 566 in
>>>>> /home/lib/petsc-3.2-p2/src/vec/vec/interface/vector.c
>>>>> [8]PETSC ERROR: KSPDefaultConvergedDestroy() line 669 in
>>>>> /home/lib/petsc-3.2-p2/src/ksp/ksp/interface/iterativ.c
>>>>> [8]PETSC ERROR: KSPDestroy() line 758 in
>>>>> /home/lib/petsc-3.2-p2/src/ksp/ksp/interface/itfunc.c
>>>>> Is it my fault?
>>>>> Regards,
>>>>> Alexander
>>>>> On 21.09.2011 15:36, Barry Smith wrote:
>>>>>> On Sep 21, 2011, at 2:39 AM, Alexander Grayver wrote:
>>>>>>> Hong, Barry,
>>>>>>> Thanks! Sorry for not to be clear, but Barry right, my question was
>>>>>>> how to get back to DefaultConvergenceTest in case of LSQR solver.
>>>>>>> Barry, yes, both versions give the same two norms.
>>>>>>> Can you clarify please how to implement that in Fortran:
>>>>>>> void *cctx;
>>>>>>> KSPDefaultConvergedCreate(&cctx);
>>>>>>> KSPSetConvergenceTest(ksp,KSPDefaultConverged,cctx);
>>>>>>      It should be almost the same
>>>>>>       call
>>>>>>      Barry
>>>>>>> I'm a little bit confused about cctx parameter.
>>>>>>> Regards,
>>>>>>> Alexander
>>>>>>> On 21.09.2011 01:10, Barry Smith wrote:
>>>>>>>> It has its own monitor that provides additional information
>>>>>>>> -ksp_monitor_lsqr
>>>>>>>> You can also remove the new convergence test and get back the old
>>>>>>>> one with code like
>>>>>>>> void *cctx;
>>>>>>>> after the KSPType is set to LSQR. So if you are happy with the old
>>>>>>>> test.
>>>>>>>>     Do both versions give the same first two norms?
>>>>>>>>> 0 KSP Residual norm 9.386670021557e-17
>>>>>>>>>    1 KSP Residual norm 8.258308650175e-17
>>>>>>>>     Barry
>>>>>>>> On Sep 20, 2011, at 4:40 AM, Alexander Grayver wrote:
>>>>>>>>> Hello,
>>>>>>>>> In comparison with petsc-3.1-p7 in the latest petsc LSQR solver
>>>>>>>>> behaves differently.
>>>>>>>>> In petsc31 I had:
>>>>>>>>> 95 KSP Residual norm 9.341367317075e-18
>>>>>>>>> Linear solve converged due to CONVERGED_RTOL iterations 95
>>>>>>>>> KSP Object:
>>>>>>>>>    type: lsqr
>>>>>>>>>    maximum iterations=200, initial guess is zero
>>>>>>>>>    tolerances:  relative=0.1, absolute=1e-50, divergence=10000
>>>>>>>>>    left preconditioning
>>>>>>>>>    using PRECONDITIONED norm type for convergence test
>>>>>>>>> PC Object:
>>>>>>>>>    type: none
>>>>>>>>>    linear system matrix = precond matrix:
>>>>>>>>>    Matrix Object:
>>>>>>>>>      type=shell, rows=19584, cols=19584
>>>>>>>>> relative residual norm =    0.9951737192872134E-01
>>>>>>>>> Now, with petsc32 I have:
>>>>>>>>> Linear solve converged due to CONVERGED_RTOL_NORMAL iterations 1
>>>>>>>>> KSP Object: 12 MPI processes
>>>>>>>>>    type: lsqr
>>>>>>>>>    using UNPRECONDITIONED norm type for convergence test
>>>>>>>>> PC Object: 12 MPI processes
>>>>>>>>>    type: none
>>>>>>>>>    Matrix Object:   12 MPI processes
>>>>>>>>>      type: shell
>>>>>>>>> relative residual norm =    0.8797910900468064E+00
>>>>>>>>> So I found new convergence test here which sets
>>>>>>>>> CONVERGED_RTOL_NORMAL:
>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/KSP/KSPLSQRDefaultConverged.html
>>>>>>>>> The question is, how to interpret this new test and make it
>>>>>>>>> works properly for me?
>>>>>>>>> Thanks in advance.
>>>>>>>>> Regards,
>>>>>>>>> Alexander
