[petsc-users] Convergence Criteria?
Alan Wei zhenglun.wei at gmail.com
Tue Sep 20 22:47:33 CDT 2011
Dear Dr. Smith,
    I figure out this problem. Actually, I made my own RHS, but I did not
multiply them by the volume (dx*dy).
    However, I met another problem. All values calculated from this example
are exactly opposite to values from my own code. I wonder if the RHS I input
by ComputeRHS are the really RHS or -1.*RHS?
thanks in advance,
Alan
On Mon, Sep 19, 2011 at 8:43 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 19, 2011, at 6:25 PM, Alan Wei wrote:
> > Dear folks,
> >     I hope you guys are having a nice day.
> >     I'm reading the /src/ksp/ksp/examples/tutorials/ex29.c.html and
> wonder how to set up the convergence criteria?
>    -ksp_rtol 1.e-10 for example
>   Run with -ksp_monitor_true_residual -ksp_converged_reason
> > Currently I use it as a poisson solver to solve a Poisson Equation with
> three direction Neumann BC's and one direction Diriechlet BC's. It seems
> very bad on it.
>     Hmm, multigrid should likely converge well. Are you sure you've set the
> BC's correctly?
>   Barry
> > thanks in advance,
> > Alan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110920/e6e59964/attachment-0001.htm>
