[petsc-users] Matrix Factorization fill
Rongliang Chen rongliang.chan at gmail.com
Tue Sep 20 19:02:29 CDT 2011
I have a question about the Sparse Matrix Factorization fill.
Following the manual, I use the option "-info" and get the following result:
[0] MatLUFactorSymbolic_SeqAIJ(): Reallocs 0 Fill ratio:given 5 needed
5.0746e-05
[0] MatLUFactorSymbolic_SeqAIJ(): Run with -pc_factor_fill 5.0746e-05 or use
[0] MatLUFactorSymbolic_SeqAIJ(): PCFactorSetFill(pc,5.0746e-05);
What's the numbers mean in "Reallocs 0 Fill ratio:given 5 needed
5.0746e-05"?
Does the " Run with -pc_factor_fill 5.0746e-05 or use" mean that I should
run my code with option " -pc_factor_fill 5.0746e-05"?
But when I run my code with option "-snes_view", I get "factor fill ratio
given 5, needed 3.28701".
So what should I give to the option "-pc_factor_fill", 3.28701 or
5.0746e-05? Thanks.
Best,
Rongliang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110920/5f543bbf/attachment.htm>
