[petsc-users] [petsc-3.2] LSQR new convergence test
Hong Zhang
hzhang at mcs.anl.gov
Tue Sep 20 09:35:03 CDT 2011
Alexander:
I'm not sure these two runs use the same tolerance.
The output of petsc-3.2 gives more details about the solver used.
Try a smaller -ksp_rtol, e.g., '-ksp_rtol 1.e-12', which likely allows
more KSP iterations
and produce better final result.
You may also use preconditioner to improve convergence.
Hong
> In petsc31 I had:
> 0 KSP Residual norm 9.386670021557e-17
> 95 KSP Residual norm 9.341367317075e-18
> Linear solve converged due to CONVERGED_RTOL iterations 95
> tolerances: relative=0.1, absolute=1e-50, divergence=10000
> left preconditioning
> using PRECONDITIONED norm type for convergence test
> PC Object:
> type: none
> linear system matrix = precond matrix:
> Matrix Object:
> type=shell, rows=19584, cols=19584
> relative residual norm = 0.9951737192872134E-01
> Now, with petsc32 I have:
> 1 KSP Residual norm 8.258308650175e-17
> Linear solve converged due to CONVERGED_RTOL_NORMAL iterations 1
> KSP Object: 12 MPI processes
> type: lsqr
> maximum iterations=200, initial guess is zero
> using UNPRECONDITIONED norm type for convergence test
> PC Object: 12 MPI processes
> type: none
> Matrix Object: 12 MPI processes
> type: shell
> relative residual norm = 0.8797910900468064E+00
> So I found new convergence test here which sets CONVERGED_RTOL_NORMAL:
> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/KSP/KSPLSQRDefaultConverged.html
> The question is, how to interpret this new test and make it works properly
> for me?
> Thanks in advance.
> Regards,
> Alexander
