[petsc-users] floating region help
Tue Sep 20 03:35:00 CDT 2011
2011/9/20 Gong Ding <gdiso at ustc.edu>
> Since the conductance of left part and right part is low, the middle region
> is floating.
Not really floating, just sensitive to parameters. It has a unique value, of
physical interest, but if you change the conductivity or thickness of the
thin region on either side, then it's value changes significantly. This is
an ill-conditioned problem, but it's ill-conditioned for physically
meaningful reasons. It's not singular and the smallest singular value has
great significance, so a null space method is not appropriate. You could
reformulate for a slightly different problem which would have a constant
null space, but not for this problem.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110920/ecf28677/attachment.htm>
