[petsc-users] Problem with PETSc-3.2 configuration
Satish Balay
balay at mcs.anl.gov
Wed Sep 14 12:52:38 CDT 2011
Glad its working now.
Wrt newer compilers - usually sysadmins [for clusters] install
separate copies of newer compilers [and leave the default system
compiler untouched]. They also install another copy of MPI with this
new set of compilers.
This workarround is ok for getting going with PETSc - but gfortran
[prior to 4.3] has some f90 deficiencies - so some of the petsc f90
interface doesn't work because of this. So its good to use newer set
of compilers. [However if using PETSc only from c/c++ - you can ignore
this issue]
Satish
On Wed, 14 Sep 2011, Rongliang Chen wrote:
> Hi Satish and Barry,
> Thanks for your reply.
> It works by using optimized build.
> This is a supercomputer and I do not have the permission to update the
> compliers.
> Best,
> Rongliang
> > Message: 2
> > Date: Tue, 13 Sep 2011 18:13:31 -0500 (CDT)
> > From: Satish Balay <balay at mcs.anl.gov>
> > Subject: Re: [petsc-users] Problem with PETSc-3.2 configuration
> > To: PETSc users list <petsc-users at mcs.anl.gov>
> > Message-ID: <alpine.LFD.2.02.1109131806240.2462 at asterix>
> > Content-Type: TEXT/PLAIN; charset=US-ASCII
> > Ok - this is on a RHEL5 box. And I'm able to reproduce the internal
> > compiler error.
> > > mumps_static_mapping.F:333: internal compiler error: in
> > modified_type_die, at dwarf2out.c:8495
> > The error is in debug symbol handler in the compiler. Looks like you
> > can workarround this by using optized build. i.e
> > --with-debugging=0
> > or debug build with:
> > [default --with-debugging=1 ] FOPTFLAGS='-g -O'
> > Satish
> > Message: 3
> > Date: Tue, 13 Sep 2011 19:48:46 -0500
> > From: Barry Smith <bsmith at mcs.anl.gov>
> > Message-ID: <B1D68042-D7ED-43D7-88C8-BF42A927360A at mcs.anl.gov>
> > Content-Type: text/plain; charset=us-ascii
> > Also that gfortran compiler is terribly old, you really should install the
> > 4.6 version of the Gnu compiler suite instead of living with that old stuff.
> > Barry
> > compiler error.
> > > --with-debugging=0
> > > Satish
